How do you tell when an '82 alternator is on its way out?
Is was driving my '82 930 the other night, and I thought that the lights got bright a couple times. I checked the belt, and it was a tad loose. So I tigntened it. A breif drive with EVERYTHING on and I saw no power fluctuations.
I just read in a Motorbooks Porsche buyers guide that this car has a 1,050 watt alternator. Appearently, some of these alternators like to overcharge the battery and burn out other stuff.
How do you check if its overcharging?
Karl
Old 08-20-2010, 09:15 AM
rnln's Avatar
start the car, let it idle, measure the voltage. Usually it's around 14+ volts. If it's 15v or more, it's over charging. I don't remember the exact number but around there.
Fat butt 911, 1987
Old 08-20-2010, 09:50 AM
carreraken's Avatar
Had similar symptoms when mine went out. Used a voltmeter to monitor the voltage and it would occasionally spike to 15v. Had the alternator replaced.
You can also get a cheap voltage monitor that plugs into the cigarette lighter - that's what I use now.
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 08-20-2010, 10:23 AM
13.9 volts.
Geuss it was the loose belt.
Thanks!
Old 08-20-2010, 10:35 AM
