Spark Plug and gap recommmendation 73.5 CIS
I've come across several numbers and gap sizes for my 73.5' 2.4 with CIS. Stock with under 100K miles. NGK, Bosch, .022, .024,.028, ? WR5DP, W5CC, WR7CC, BP5, BP6, BP8 ES???? TIA
Randy
73.5 911 T
97' C2S
06' C2S
Old 08-16-2010, 10:36 AM
if a Bosch CD unit use stock factory plug gap as per its design
the CIS should run BPR7ES or BPR8ES clean imho.
ps: NGK
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-16-2010, 11:03 AM
The factory manual says .022 for a plug gap. What about that?
Randy
73.5 911 T
97' C2S
06' C2S
Old 08-16-2010, 12:58 PM
.022 yep.
Forget about the Bosch copper plugs. I bought everyone left in the western hemisphere and that was only seven of 'em!!!!!!!!!!!!!!!!
Look at NGK.
Bob
73.5T in Sepia of course
Old 08-16-2010, 01:40 PM
Thanks for the suggestions. Anything different if Permatune replaces the Bosch unit?
Randy
73.5 911 T
97' C2S
06' C2S
Old 08-17-2010, 08:57 AM
i never followed what gap Permatune can tolerate so i just set them to "76/77 Tehnical Specifications" booklet Bosch specs of .028" as some 1977 came with factory old model Permatunes like mine
and according to a local pope the ideal gap for our combustion chambers etc is .040" which i use now with the MSD
some members use larger than stock gaps with Bosch and Permatunes
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2010, 09:49 AM
Thanks for all the input!
Randy
73.5 911 T
97' C2S
06' C2S
Old 08-18-2010, 09:56 AM
