VJB 911S
brake upgrade
hello,
can someone tell me if is possible to install '92 c2 turbo brakes (calipers and rotors) in my '79 sc? How can it be done?
Old 06-03-2010, 03:16 PM
AutoBahned
RWebb's Avatar
what problem are you having?
Old 06-03-2010, 03:25 PM
VJB 911S
Just got a full set of '92 c2 turbo brakes from a friend, and I will like to install this brake set in my '79 911sc. thanks for your help.
Old 06-06-2010, 05:34 PM
Max Sluiter
Flieger's Avatar
Contact Bill Verberg via this BBS.
Old 06-06-2010, 06:56 PM
Bill Verburg's Avatar
Originally Posted by redlineborges View Post
hello,
front
you will need a set of caliper adapters, contact VCI
965 rotors will be hard to fit to a 911, you will need anulus type 322x32mm rotor and flat hats to bolt to the 911 hubs
back
the 964 calipers can be modified to use w/ 930 rear rotors, fill the existing mounting holes and redrill for the 3" 911 trailing arm and the 309x28mm 930 rotors
Bill Verburg
Old 06-07-2010, 04:14 AM
VJB 911S
Thanks Bill! Do you have any part numbers for the modification bracket part number or supplier? Also, rotors part number or supplier?
I'm in Miami, Fl and theres no Porsche shop that work on old cars.
Thanks!
Old 06-07-2010, 06:55 PM
I can provide the 322x32mm rotors with flat hats that will fit your hubs, if that helps.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-07-2010, 08:29 PM
OCD project capitan
BigD9146gt's Avatar
I've made a set in the past based off what others have done. Front adapters bolt to both struts and calipers, inner caliper half needs to be machined, drilled and tapped for adapters to bolt to. I did this for Clint at RebelRacingProducts, I think I still have the CAD drawings somewhere...
Cheers, Don
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 06-07-2010, 08:38 PM
VJB 911S
Thank you guys, whatever you can come out with will be very helpful, since the only shop I know around my area all they do is sell chip and wheels for 996 and 997.
Old 06-08-2010, 03:25 AM
Hi!
Might not be "politically correct" to mention them on the PP forum, but ****** Auto (Competive web shop etc) in Miami have mechanics who works on older Porsches, as far as I know. I have been there a few times to pick up some parts for my 78 SC, since I visit Miami a lot, and I see all sorts of ages of Porsches being worked on in their shop.
They are located a couple of blocks from The Collection car store, also well worth a visit
Regards,
Christian
Old 08-16-2010, 11:09 AM
Thanks!
Call VCI they will tell you what you need
Bill Verburg
Old 08-16-2010, 02:25 PM
