i couldnt even change a flat this morning...
I couldn't remove the port near the rear tire to access hole to put jack into. Am I missing something here? I even damaged it by pulling with a screw driver.
Old 08-19-2010, 05:35 AM
If you tried to remove the squarish, black plastic one, there's nothing holding it in but friction.
JR
Old 08-19-2010, 05:37 AM
Friend of Warren
Something tells me you were trying to remove the round cover you remove to extract the rear torsion bar. The jack hole is midway between the front and rear wheels. The cover is square and black plastic.
Kurt V
Old 08-19-2010, 06:13 AM
Northern Motorhead
wildcat077's Avatar
I also have the feeling you were trying to remove the wrong cover !
Be very careful with the factory jack when you try to lift your car through the mid body
access.
A lot of people carry scissor jacks instead of the factory,whatever you can call it jack ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-19-2010, 06:18 AM
That's explains it, it was very dark when I was doing this. Then how does the round thingy come that's closest to rear tire, I scratched it all up and bent it?
Old 08-19-2010, 06:37 AM
Friend of Warren
Look at the backside and you will see how to remove the cover.
Kurt V
Old 08-19-2010, 06:56 AM
MBruns for President
JeremyD's Avatar
and you can't remove the round thingy unless you remove the rocker panels, especially if you have a 1987 car or later...
You only do that to set the torsion bar height.
Old 08-19-2010, 07:21 AM
I'm here to cause trouble
jimbauman's Avatar
The torsion bar access plate is held in place from the back with a small bracket and nut. Easy to replace the damaged one....
JB
PS: ya the rocker panels are a bit of a pain, but then you have the opportunity to clean up all the dirt and crap underneath it!
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 08-19-2010, 07:35 AM
I feel stupid, but like I said very dark and that was the first access panel I saw.
Old 08-19-2010, 08:17 AM
put the screwdriver down and step back.
206 637 4071
Old 08-19-2010, 08:21 AM
muck-raker
kidrock's Avatar
there's one for the "whoops" file...thank goodness it's an easy fix.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-19-2010, 08:50 AM
Wavey's Avatar
Made you cringe too, huh John?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 08-19-2010, 09:33 AM
JeremyD's Avatar
Dude - you did the right thing by coming here - there is a wealth of knowledge here - JW is one of the best.
We have all done stupid things - not everybody has ponied up to.
Search for "stupid things" people have done - at least for a chuckle. I myself have overfilled the crankcase and fogged the neighborhood for mosquitos.
My first Porsche a 964 - I didn't even change the oil myself on it.
The next one - a 1987 - I did brakes/suspension and even dug into the engine.
This one - suspension/brakes - really nothing intimidates me anymore. You have to start somewhere.
no big deal...
Old 08-19-2010, 09:56 AM
winter
Winter's Avatar
hey, at least you didn't put antifreeze into the oil tank!
Tom
'76 Targa
Old 08-19-2010, 10:27 AM
muck-raker
kidrock's Avatar
Boy, I'd love to hear that story.
STONE
Old 08-19-2010, 12:31 PM
dshepp806's Avatar
No worries,..easily fixable.......these events are good lessons,..and you're never rid of them in the back of your mind........wait till you get several under your belt.....
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-19-2010, 12:53 PM
2002 996 C4S
jcsjcs's Avatar
Destroyed my Screw Jack two nights ago. Didn't chuck the wheels and the car rolled as I jacked it up. Fortunately only the jack was ruined.
Time to get a 944 aluminum one.
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 08-19-2010, 01:34 PM
winter
Winter's Avatar
Don't jump to conclusions, I didn't do that! Just saying that he could have REALLY screwed up, instead of sorta screwed up.
Regardless, a good reminder to not "force" things.
At least this is a relatively simple fix.
Tom
'76 Targa
Old 08-19-2010, 01:46 PM
Senior Advisor
James Brown's Avatar
OK, so let's think of what would happen IF you got the torsion bar cover off and put the jack in the hole and started to screw....
08 Cayenne Turbo
Old 08-19-2010, 01:58 PM
Porsche jacks are crap. I gave up on mine when it sank into hot asphalt at the side of the road on a hot August day. I now have a screw type that hooks up to a jack pad that inserts into the jack port.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-19-2010, 03:37 PM
