cantdrv55's Avatar
What can I use to clean my Fuchs again?
The car has been in storage a while. Battery is dead, corrosion from it is into the compartment, brake is soft and the polished lips on the Fuchs have dots of rust. First things first, beautify the car again.
So, what can I use to get the spots off the Fuchs and get them shiny again?
Old 09-21-2010, 03:53 PM
Indeed, not a heavy coating and you can wipe a considrable amount off afterwards and be amazed at what it does.....
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-21-2010, 05:28 PM
79 Euro's Avatar
I used the Vaseline yesterday. A dab goes a long way. Cotton balls were helpful. Results were amazing.
Andy Kay
Kennedale, TX
817.948.8538
1979 911 SC Euro - Guards Red
Old 09-21-2010, 06:08 PM
cantdrv55's Avatar
Thanks guys!
Old 09-21-2010, 09:01 PM
w00t911's Avatar
Vaseline even for Fuch's that are color matched to exterior paint. I don't think so.
Old 09-21-2010, 10:20 PM
scottbombedout's Avatar
The vaseline can go on anodized lips.
88 carrera
Using the teutonic shift method since 1990.
Old 09-22-2010, 01:43 AM
WPOZZZ's Avatar
For polished Fuchs, you can use Mothers Aluminum Polish, Flitz or any other metal polish.
Old 09-22-2010, 03:20 AM
Platinum Member
dad911's Avatar
IMHO your priorities are skewed.... get that battery out and stop the corrosion
Old 09-22-2010, 05:17 AM
cantdrv55's Avatar
The battery's out and connected to a charger.
Old 09-22-2010, 09:49 AM
scotyp's Avatar
If spots are not too deep, a nice cleaner wax would work too...I used the light green Zymol on my Fuchs and it worked great!
Old 09-22-2010, 10:04 AM
drl911's Avatar
+1 for Mother's on aluminum polished lips.
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 09-22-2010, 10:10 AM
burgermeister's Avatar
Rust on an aluminum rim?
Not as good as the vaseline but also functional is WD-40 sprayed on a paper towel.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-22-2010, 04:44 PM
