Drisump's Avatar
Odometer
I went to the Parts Obsolete event this weekend in my 85 3.2, and on route my odometer and tripometer stopped working, the speedo is working fine....so am I correct in assuming that this is likely a problem inside the gauge? (the 85 speedo is electronic so I assume there is a motor inside the instrument to rotate the tumblers based on the speedo's input. I just want to make sure that the speedo is likely the problem before sending it for repair....Thanks
Old 07-18-2011, 02:54 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yes, the wheels may have fractured for the Odo or maybe one of the green power lead solders may have fractured.
If your needle is working then it is probably the sprockets.
Jim
'85 Carrera Targa
PCA/POC
Old 07-18-2011, 03:27 PM
Drisump's Avatar
Thank you sir, I guess I should send it to North Hollywood Speedometer then.....
Old 07-18-2011, 04:48 PM
DRACO A5OG's Avatar
If you have to or you can ty to rebuild it yourself. Are you in Canada? If so isn't there someone close by?
NHS is great but the shipping cost???
'85 Carrera Targa
PCA/POC
Old 07-18-2011, 04:51 PM
Registered knucklehead
83-911SC cab's Avatar
This might help ij your descision making process
Odometer Gear replacement for Electronic Speedometers (long)
Gregg
1983 911 SC Cabriolet, 1989 944 S2
1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455
2000 BMW 528i Touring, 2005 GMC Sierra
Old 07-18-2011, 05:29 PM
If you want to DIY, do a search and you can find procedures and a source for the gears. If you send to NH Speedo, it's about $140. I had them do one of mine a couple of months ago. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 07-18-2011, 05:34 PM
Drisump's Avatar
Haven't investigated the availability of local talent for this job, so I'll do so. Thanks for the self repair thread, very useful.....I may even elect to "give it a bash" next winter. Cheers
Old 07-19-2011, 06:26 AM
