Inner bearing won't fit on spindle??
I can't figure out what is going on? I have a 1982 911SC that I've changed the bearings on the left front just fine. The right inner bearing won't slide on to the spindle. I have a spare and it will not fit either. I checked the part number listed by our host and I ordered the one listed for this car. What am I missing? It does not make sense that one side fits and the other does not? Any thoughts or suggestions are welcome.
82SC Track Car |
Did you freeze the bearing before installation? (If not, do it this way.)
The one that slid on probably has a bit more wear but as long as it doesn't rotate around the spindle you should be good.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne Last edited by Oh Haha; 08-21-2010 at 11:41 AM.. |
abit off center
It should not be a press fit, check the spindle for any burrs or nicks, it does not take much to screw up the fit. Is the bearing already in the hub or are you trying to just slide the bearing on?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
UFLYICU
definitely freeze it, and hit the spindle with a map torch momentarily just before you slide it on. Should do the trick. Inspect the spindle VERY closely for even the slightest burr before install.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 08-21-2010 at 11:38 AM.. |
I looked at the spindle and felt around it but I will give another check.
82SC Track Car |
Max Sluiter
If the bearing needs to fit over the spindle, don't you need to heat the bearing and cool the spindle?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
UFLYICU
OOPS! you're right. I was thinking about my rear bearings. My bad.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
The spindle looks and feels fine. It is almost like these bearings are slightly off. I'm going to run some sand paper around the inner ring and see if that does anything. I have not heard of a bad batch of bearing.
There is no heating and cooling stuff going on here. This is the bearing that just slide on and off when you take you hub off to change rotors. This thing should be a good fit but slide right on.
82SC Track Car |
Forced Induction Junkie
Is the spindle discolored at all? Any signs of overheating, seizing?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
No, I was just doing this as preventative maintenance. I had no issues at all until I tried to install these new bearings. I will call Pelican on Monday to see if they have had other reports of fitment issues. FWIW I took off a FAG and am trying to install a SKF.
82SC Track Car |
Never had to heat or cool front bearings (except when installing the races in the hub), they just slide right on..
Gary R. |
82SC Track Car |
Well, when the OP called the item the "inner" bearing I believed it to be the race/bearing combo. Sorry for the mispost.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Does it fit properly in the existing race (assume you didn't install the new matching races)? And if you did, was there an issue installing the races?
Gary R. |
I'm assuming you could re-install the bearing you took off; i.e. not damaged or distroyed. Measure the inner diameter of the removed bearing with a micrometer. Measure the new bearing looking for the same inner diameter. Measure several places around the circumference of the new mearing to make sure it's round. If everything measures out, it must fit. If not, you've confirmed the problem and can report the mis-sized new beaaring to our host.
If the part #'s are the same as the old bearing they should slide on the spindle easily.
Is it possible that the spindle is different on that side?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Gary - I did install the new race in the hub and I have a spare bearing/race in a box as well. Neither one fits. The bearing race combo seems normal and came out of the box looking good.
L8brakr - I ran out of time but that's the direction I'm heading. I was also going to try the hub bearing combo from the other side of the car to see if it slides on normally. I can't imagine anything is wrong with the spindle. I removed the old hub/bearing with ease and the car has been sitting on jack stands waiting for me to reinstall the new bearings/hub. I'll have to get into the dimension of these things and will report back. Thank you for all the good thoughts and help.
82SC Track Car |
Well, it is possible it has changed in some way but I need to get some dimensions to confirm what is going on. My first thought was I ordered the wrong bearing. It is such a close fit. I could probably heat it up and drive it on but then I'd be totally messed up when I had to remove it. That is, if the bearing wasn't messed up in the process.
82SC Track Car |
Senior Advisor
Don't heat or cool anything. If the bearing race does not fit out of the box on a clean spindle, don't use it. If you ever get it all the way on (pounding, heat, cool, hydraulic, whatever) good luck removing it. You will destroy the inner bearing and grease seal at the least.
08 Cayenne Turbo |
Tell me about it. I had a hard enough time just taking this off after it didn't fit properly. Agreed 100%.
82SC Track Car |
