www.ALBERTOBILLA.it
cyber2213's Avatar
Send a message via MSN to cyber2213 Send a message via Skype™ to cyber2213
Unhappy New Problem..
New Problem ..
well .... I found a broblema in my car (Porsche 3.0 RSR) from 4000 to 5000 rpm, I installed an alternator of 3.2 with a battery racing (small).
it is possible that this problem is caused by the alternator with this battery?
Old 08-29-2010, 10:33 AM
www.ALBERTOBILLA.it
cyber2213's Avatar
From 4000 to 5000 rpm not speed up ...
knead ... as if it were a question of electricity
The alternator is charging the battery at 14 amps, but sometimes the rev counter jumps up to full scale ...
Old 08-29-2010, 10:47 AM
First thing is check all your grounds.....
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-29-2010, 11:22 AM
www.ALBERTOBILLA.it
cyber2213's Avatar
the electrical system is new and is for racing ...
the alternator charging at 14 volts, not amps .. sorry
What is it that can break inside the alternator of 3.2??
What can create interference with the engine tachometer?
Old 08-29-2010, 11:29 AM
If the 3.2 alternator is not new, things that can be bad include:
- bearings ( not related to your problem)
- slip rings worn with major grooves
- bad commutator brushes,
- bad voltage regulator...internal. Did RSR use external voltage regulator?
Why did you use a 3.2 alternator with your earier RSR?. Is it a real RSR? What is the proper alternator for RSR?. Does the 3.2 alternator fit your original housing?. I think we need more information.
Others with more and better electrical understanding can chime-in at this point.
Wil Ferch
Old 08-29-2010, 11:40 AM
A bad voltage regulator can overcharge and cause strange lights and tach symptoms. But at 14 v it's not overcharging. Don't know your new "small" battery but if easy, try a regular full size battery. The little one may let some voltage spikes get through. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 08-29-2010, 11:42 AM
www.ALBERTOBILLA.it
cyber2213's Avatar
is not an original alternator RSR for comfort .. because in the original alternator works with an external voltage regulator should be adjusted to the range of engine rpm ...
Asthe dimentione on the space is the original fan is RSR
My current alternator to charge 14volt 14.5volt, a question that came to me and about the range of rpm in that makes the car ..
8500 v 7500
Old 08-29-2010, 11:58 AM
E Sully's Avatar
Alternator sounds fine. What is your ignition system. Ignition could be causing the problem with the tachometer. It is what sends the signal to the tachometer.
Ed
1973.5 T
Old 08-29-2010, 12:56 PM
www.ALBERTOBILLA.it
cyber2213's Avatar
MFI with Bosch 6 pin box cd
Old 08-29-2010, 02:10 PM
Max Sluiter
Flieger's Avatar
Check the points gap and condition.
Old 08-29-2010, 07:41 PM
Max Sluiter
Flieger's Avatar
OK, I got your reply on EarlyS
Old 08-29-2010, 08:00 PM
www.ALBERTOBILLA.it
cyber2213's Avatar
www.ALBERTOBILLA.it
Old 08-30-2010, 05:52 AM
Max Sluiter
Flieger's Avatar
Old 08-30-2010, 11:07 AM
