<insert witty title here>
Never heard of the woodruff key - just had to look it up, and no, I'm not at all positive that it's properly aligned and seated. I never saw it disassembling stuff (which is why I had no idea what you're talking about and had to search it) but it's entirely possible it just fell out and got lost. I'll pull it apart and look. Thanks!
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
If you lost it, another can be found at your local hardware store.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Christien:
Woodruff key is a semi-circular piece of metal that fits into a longitudinal groove in a shaft, and the also on the piece being rotated. Shameless plug...look at my alternator/voltage regulator repair article.... especially item 12 where this woodruff key is hinted-at. Pelican Technical Article: 911 Alternator & Voltage Regulator Removal/Replacement Also...for you guys saying you looked at the brushes and it takes $5 to replace.....I would advise AT LEAST having someone look at the copper slip rings that these brushes ride-on...they will likely be heavily grooved and should be replaced. Then the diode and bearing checks. A good alternator shop can do this and refresh/repair at reasonable cost.
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 09-15-2010 at 09:50 AM.. |
I never thought to check the Pelican articles - I was just using the 101 book. That article is much more detailed - thanks!
Thread Tools | |
Rate This Thread | |
