Took off valve cover - See daylight over tubes
Can someone explain what going on here, might I be missing a gasket or something at my oil return tubes?
I power-washed my engine prior to starting a valve adjustment, and I swear some water came out with a few drops of oil when I took the lower covers off.
Old 09-05-2010, 05:21 PM
abit off center
cgarr's Avatar
Thats open between the cylinder heads. or do you see light inside the return tube?
______________________
Craig
G2Performance
Old 09-05-2010, 05:30 PM
No light in the tube.
That's what I'm talking about, thank you for the picture.
If you drive in the rain, doesn't water get into the heads and then into your oil?
Old 09-05-2010, 06:16 PM
abit off center
cgarr's Avatar
You had water laying in the lower cover in that open cavity. The lower cover it tilted inward at the bottom and you will collect water in that open area.
Craig
G2Performance
Old 09-05-2010, 06:24 PM
That sounds correct, but why is it done this way?
Isn't water in the engine bad?
On a hard turn I'm pretty sure that water can get mixed into the main oil flow.
Old 09-05-2010, 06:47 PM
abit off center
cgarr's Avatar
The valve cover seals between that open area and the oil, When you twin plug an engine this is where you bore the hole for the lower plugs, its open to free air, or water but sealed from the oil. The upper covers are the same way.
Craig
G2Performance
Old 09-05-2010, 06:57 PM
I trust with time I will understand the design better.
For now, I thank you for all the information you have provided, and hope some of it sinks in.
I have been doing a lot of work on the car before I insure it for the road. The "to-do" list is slowly shrinking.
It took me almost two days in +90 degree weather just to switch the wipe blades, it was just one little mechanic man in the 101 Projects book.
Old 09-05-2010, 07:46 PM
Max Sluiter
Flieger's Avatar
Basically, Porsche did not bother to cut that bit of the valve cover out.
Old 09-05-2010, 08:09 PM
Senior Advisor
James Brown's Avatar
LOL, love this stuff, lots pf people freak out at there first valve adjustment!! Think of the engine as 6 individual cylinders arranged in two banks. The space between the cylinders was left open so air (remember air cools this thing) can circulate around the very hot heads/exhaust. Porsche could have used 12 small valve covers instead of the 4 valve covers. Look at your first picture and see how the gasket snakes around the rocker arm pocket. You see oil on the inside of the gasket and air/oil/crap/light on the outside of the gasket.
How many miles on the engine? and your just noticing it now? sorry, couldn't resist.
08 Cayenne Turbo
Old 09-06-2010, 01:34 PM
