jwakil's Avatar
Will shock replacement only require re-alignment?
OK, so I'm thinking of replacing both front and rear shocks on my 83SC, and maybe next year do the torsion bars/bushings. I don't want to do both at the same time for time and financial reasons. I was wondering if just replacing the front shock inserts and rear shocks would require a re-alignment or not? Obviously after the torsion bars I would do it.
Old 09-10-2010, 07:35 AM
19 years and 17k posts...
azasadny's Avatar
The front shock replacement requires re-alignment, but in my case, the guy who did the alignment said that everything was "very close" and only needed very slight adjustment.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-10-2010, 09:25 AM
PRO Motorsports
Tyson Schmidt's Avatar
It can be done without disrupting the current alignment settings by leaving the upper strut mounts untouched, and simply removing the large nut in the center of the mount to remove the top of the insets from the the mount.
But what may necessitate an alignment regardless, is the fact that it will usually raise the ride height due to increased gas pressure in the new shocks/struts.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 09-10-2010, 09:27 AM
Nine9six's Avatar
+ 1 on the post above.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 09-10-2010, 10:44 AM
I changed my front shocks a couple of years ago - replaced the 20 year old oil filled shocks with new gas inserts - and it didn't need a realignment. Also in Wayne's book it doesn't mention any need to realign when you change the shocks. I recently had my alignment checked and it is absolutely spot on, so I think you will be fine.
Charles
'84 911 3.2
Old 09-10-2010, 04:21 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Just went through this.
I did re-check the alignment.
You may want to drive the car for a while, then re-check the ride height on all four corners,
and the alignment.
pm me for the ride height on our '86.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-10-2010, 04:24 PM
HarryD's Avatar
I do not know the correct answer but I think if: 1-The ride height at EACH wheel is the same before and after the strut change; AND 2-You did not move the upper adjustment plate then you would be ok.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-10-2010, 04:43 PM
When I got my car it needed spring plate bushings and the ride height adjusted up. When talking to Steve Alarcon about it, we decided that based on my budget restraints it would be prudent to change the rear bushings, add new shocks to the rear, do an alignment and corner balance all at the same time. The front shocks could be changed later without incurring the cost of another alignment and corner balance if and when I decided they needed changing.
So far I've no complaints and most riders love the way the car rides.
Scott
'78 SC mit Sportomatic - Sold
Old 09-10-2010, 05:25 PM
bonkers's Avatar
When John Walker replaced the shocks on my '88 he highly recommended getting an alignment and when I took a drive a week afterwards to help the new shocks settle in and to get a feel for the car while the handling was not good, it was decidedly squirrely.
After the alignment the handling was perfect and the car was a joy to drive.
I don't know how old your shocks are but mine were original as far as I could tell and my ride hide raised significantly before settling down to a level a bit higher than before.
If your shocks are old, I would plan and budget for an alignment a couple of weeks after replacing them, then take the car for a drive after the shocks are replaced but before the alignment to feel the adverse effects on handling for yourself.
Carrera 3.2 - "Faster, Stronger, Better"
Old 09-10-2010, 05:32 PM
