Wine User
Chip on Craigslist
Any one recognize this chip that is for sale on Craigslist?
TIA Warner
muck-raker
check this out.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Platinum Member
That is a standard eprom. No way to know how it is programmed with a visual inspection.
It could be anything including a boot rom for an old PC, an arcade game, or could be blank. |
Diss Member
As said above: If is the program burned into it that is the important thing the chip is just the repository.
... But ... That is a UV erasable EPROM. There should be a sticker or something covering the window to keep the data from being wiped.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
