2002 996 C4S
jcsjcs's Avatar
Engine back in - won't start.
Reinstalled my engine in 84 911 last night and it won't start.
Car has not been started in about 10 months.
Need some advice on how to proceed:
1) I have seen a lot of posts about injectors getting stuck. We "tapped" two of the injectors while trying to start the car multiple times. Do they all need to be "unstuck" or if we get a couple loose should the car at least start to run on a few cylinders?
2) We have spark (tested with spare spark plug) and fuel movement (as we had an open fuel line which we missed and attached after discovering the leak.)
3) We pulled off one of the connectors on an injector and don't get any voltage when cranking the engine. Should we?
4) Other posts indicate this could be a sensor problem. How can I test the various sensors to see if they are properly hooked up.
Any advice appreciated as everything is back together after a LONG time and would really like to get this resolved soon!
jcsjcs
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 09-12-2010, 07:15 AM
grateful user
don gilbert's Avatar
check your DME relay
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 09-12-2010, 07:48 AM
2002 996 C4S
jcsjcs's Avatar
Is it likely that the DME relay could go bad after a period of non-use?
Will check - but want to understand.
jcsjcs
Have: '02 996 C4S
Old 09-12-2010, 12:34 PM
Mine wouldn't start after an install, and it turned out that I had not reconnected the bundle of Brown ground wires on the left side of the engine. Are you sure these are connected?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-13-2010, 06:29 AM
Of all the sensors that could cause a complete no start, the 2 flywheel sensors are the main culprits. Not hooked up, the DME would not even know the engine was turning over, so would not fire the injectors.
Old 09-13-2010, 07:01 AM
muck-raker
kidrock's Avatar
yes...they can go bad without the slightest provocation.
All the other suggestions are also very good. I would first check the ground batch at intake #1, then the DME relay, then the 2 sensors. Start with the easy stuff first.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-13-2010, 07:04 AM
E Sully's Avatar
DME relay must be working or the fuel pump would not work.
There is spark, so I would think the speed and reference sensors are also working.
You should get voltage to the injectors when cranking. Have you made sure the connector by the shock tower is snug. Check for voltage there. This branches out to all the injectors.
Otherwise it might be the DME itself.
Ed
1973.5 T
Old 09-13-2010, 09:00 AM
kodioneill's Avatar
Reference sensors reversed?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 09-13-2010, 09:55 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Try tapping the injectors with a wodden screwdriver handle while and assistant is cranking. They are notorious for getting stuck closed when sitting more than 3 month. And sure check the the sensors (reference and speed) are not reversed.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 09-13-2010, 10:03 AM
rob911's Avatar
Ditto above ^^^ - check all cables.
The speed and reference sensors are easy to reverse. I Added coloured tape to both parts of one sensor cable.
The sensors can be tested for resistance, values in bentley manual.
AFAIK the injectors are earth switched? and cannot measure this with a volt meter. Think an oscilloscope shows square wave, with dip corresponding to low voltage when injector is open.
Does yours have immobilser? My 3.2 would not start after 9 month long rebuild. Tried all of the above and more, as I had not spark or fuel. My duaghter asked about security thing, so I refitted the immobiliser "key". Started first turn. Doh!!!!
01 Maserati 3200 GT Assetto Corsa
84 3.2 cabrio - gleaming
99 Alfa Romeo 166 3.0 V6 super - still going
03 Fiat Punto 1.2
http://www.pelicanparts.com/gallery/rob911
Old 09-13-2010, 01:34 PM
ischmitz's Avatar
Since you have spark this is not an immobilizer issue. On the 3.2 it simply would have cut power. You can confirm whether it is sensors (reversed or not good) by spraying starter fluid into the intake.
The logic is that once you have spark it could still be bad timing (reference sensor marginal). Else your problem is either stuck injectors (likely) or a damaged DME (fuel injector output stage).
Ingo
Old 09-14-2010, 06:16 AM
I first read this thread as ...................Engine In Back - won't start..
You have spark, and you have fuel, right?
I am at a loss, sorry.
Old 09-14-2010, 06:21 AM
ischmitz's Avatar
He wanted to say: "We have fuel pressure" He had a leak at one of the fuel lines and deducted correctly that the fuel pump was running during cranking.
Old 09-14-2010, 06:57 AM
Cool.
Still looking for a faulty connection to a sensor though, right?
Old 09-14-2010, 07:36 AM
Hi
Targa Me's Avatar
This happened to me once and I went into great depth looking for the problem; forgetting one of the first things auto repair had taught me... Look for the simple and obvious things first. I know you can tend to get frustrated and then all of a sudden you find yourself knee deep in Porsche.
I had replaced a clutch and when I tried to start the engine, it would crank but not fire. I searched high and low; DME, ECU, fuel pressure, alarm system, coil, sensors and after all that it turned out to be a wire harness had become unplugged from underneath the dash, just left of the steering column. I discover the loose connection as I was about to replace the ignition switch.
Look for the obvious.
Hope this helps.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 09-14-2010, 07:56 AM
2002 996 C4S
jcsjcs's Avatar
Thanks for the all the replies - this thread took off when I wasn't looking. Planning to spend a few hours this weekend and will report back.
Great suggestions!
jcsjcs
Have: '02 996 C4S
Old 09-16-2010, 02:34 PM
I'm here to cause trouble
jimbauman's Avatar
You had the engine out... what did you do to it while it was out?
Other gotcha items... other than sensor issues... did you plug in the 4-pin connector that rests on the little shelf behind the engine? Distributor in correctly? The aforementioned ground wires, including the tranny ground? The 12-pin (or is it 14?) wiring harness connector in the engine compartment is in securely, and no wires have come out of the connector block? The big ECU connector is snug into the ECU?
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 09-16-2010, 02:47 PM
2002 996 C4S
jcsjcs's Avatar
JB
That was it! Thanks for the tip.
The actual overall problem was the fact that we had 3 oil hoses BELOW the engine and 3 electrical connections ABOVE the engine after we reinserted the engine. Probably a novice mistake - which we will not make again.
Car runs GREAT after 11 months off the road.
Shifting is remarkably great!
Thanks for the help.
Another post coming to thank the entire community.
jcsjcs
Have: '02 996 C4S
Old 09-19-2010, 03:18 PM
