Alternator question: Paris Rhone and Bosch interchangeable?
It's time to replace the alternator in my '88 911. It's a Paris Rhone unit (PN: 911 603 120 05). ![]() My local Porsche parts guru says "Rebuilt Paris Rhone units are crap." He says get a new one or a rebuilt Bosch unit. Hmm. Pelican Parts has a rebuilt Paris Rhone unit for $189. I called them to ask ... no complaints they know of ... so does anyone here have experience with a rebuilt Paris Rhone alternator? If it's not up to par, does anyone know if a Bosch unit is directly interchangeable with the Paris Rhone, i.e., are the connections exactly the same? I'm getting conflicting answers. Some say I have to rewire the back ... something to do with the idiot light. Thanks in advance for your answers.
- Bob |
Yes, the connections are identical. There are only B+, D- and D+/61 on the back, these are internally regulated alternators that do not use a DF wire or external reg.
Be extremely careful, disconnect the battery negative before working on the alternator, if the B+ shorts to ground you will have an 800 amp arc welder back there, could cause personal injury or property damage.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Hi
LOL, my Paris Rhone Alt needs rebuilding about every 40k miles. What i've done is bought a second unit so there's no down-time, i just swap them out.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Thanks for the info 304065. One thing: I think you meant to disconnect the battery's positive in this particular case, right?
- Bob |
Targa Me: so you are saying that they are crap, then? What is wearing out on them -- the bearings?
- Bob |
abides.
It's a crapshoot. I bought a rebuilt Bosch, and it went bad within a week. I believe my mechanic got me another Valeo, and all has been well since then.
According to my records, my car's alternators last about 75,000 miles. I guess I'm due for another one next year.
Graham 1984 Carrera Targa Last edited by gtc; 09-21-2010 at 10:44 AM.. |
Man, I just don't get it. If the brushes, bearings and voltage regulator are replaced, why can't these reman units go the distance like the OE units? (180,000 miles in my case).
- Bob |
Hi
BP, it always seems like its the bearings that are failing.
If you disconnect the positive you still have to worry about accidentally shorting to the positive terminal. If you drop a wrench on the positive and it hits the body, spark time. If you disconnect the negative and drop a wrench on the positive and it hits the body, nothing happens.
Got ya 304065 ... thanks ... well I pulled both terminals off yesterday for good measure. Plus when it comes to ignition parts, I have no idea what wires may still be hot, and only need to find a ground and ZAAAP.
FYI, I have found a place here in Oceanside Calif, who does a total rebuild of the existing unit for $165, including high quality bearings, etc. ... not the type that last for only 40K miles. Richer Auto & Truck Electric -- (760) 757-1201 It'll be done in two days. If it's less than expected, I'll let you know, otherwise I'm a happy camper.
- Bob Last edited by Bob Prosser; 09-21-2010 at 03:40 PM.. |
