-   -   I really didn't want a project this big....yet... (http://forums.pelicanparts.com/porsche-911-technical-forum/566377-i-really-didnt-want-project-big-yet.html)
will hung 07-25-2012 06:00 AM
Looks good Glenn.
If you don't mind me asking, where did you get your fuel lines? OEM or custom? It's a project I'd like to tackle sooner than later.
JeremyD 07-25-2012 06:17 AM
Hey Glenn - what are you using for a welder? Looks good!
DaddyGlenn 07-25-2012 08:31 AM
I got OEM fuel lines from our host and my welder is a Millermatic 140 and I use an 80/20 CO2/Argon mix as a shielding gas.
DaddyGlenn 08-26-2012 05:33 PM
Another milestone reached today. I finished priming the body. Bolt-on panels are next.
http://forums.pelicanparts.com/uploa...1346027618.jpg
mcaterino 08-26-2012 08:38 PM
Exciting, Glenn. It's looking good. Nice work.
Mike
will hung 08-27-2012 04:54 AM
That's a huge milestone Glenn. Congratulations.
JeremyD 08-27-2012 04:57 AM
Yea Glenn!
DaddyGlenn 09-02-2012 05:53 PM
It has now been two years since I started the fiasco, I mean project. I guess I've made some progress. This weekend, I am starting to strip and prime the bolt on parts. So far I've got the doors, engine lid and hood down to the zinc. Tomorrow I will strip the fenders, weld up a little crack in one door and get some primer on the doors.... I hope.:rolleyes:
To see what I've been dealing with, here is a photo progression of stripping the hood.
First coat of paint remover and covered with plastic.
http://forums.pelicanparts.com/uploa...1346633114.jpg
After letting it sit for an hour, I pulled the plastic and took a razor blade to it. This is what it looked like when I was done. The most recent respray was 99% off. What you see left is the original color and the first respray. the paint was softened but not enough to scrape off.
http://forums.pelicanparts.com/uploa...1346633321.jpg
After another application of paint remover under plastic it looked much better.
Ready to scrape.
http://forums.pelicanparts.com/uploa...1346633405.jpg
What was left would easily come off with the wire wheel.
http://forums.pelicanparts.com/uploa...1346633455.jpg
The same multi-step process was required on both doors and the engine lid. Sigh...
1-ev.com 09-03-2012 05:35 AM
Great Job Glenn !!!
DaddyGlenn 09-20-2012 02:06 PM
Done with the bondo on the tub... here are a few shots.
http://forums.pelicanparts.com/uploa...1348175093.jpg
http://forums.pelicanparts.com/uploa...1348175109.jpg
http://forums.pelicanparts.com/uploa...1348175129.jpg
Next for the tub is more primer, then color. http://forums.pelicanparts.com/support/smileys/wat3.gif
Joeaksa 09-20-2012 04:12 PM
Very nice work! You doing the painting as well?
DaddyGlenn 09-20-2012 06:42 PM
I'm gonna give it a good try.
mcaterino 09-20-2012 07:43 PM
Glenn,
Funny as it may sound from someone who's driving their car, those pics make me nostalgic. I really enjoyed the body work.
Everything looks pretty good, but I have to say, your door gap in the corner looks like it tightens up a little. A little more primer and paint and it could be too close. Can you round that out a little more? I know I had to do a lot of 'shaping' in the corners.
Could just be the angle of the photo too.
Mike
maui44 09-20-2012 08:00 PM
Just FYI,
The valance you are looking at above may cause you some issues where there are any "dips" i.e., driveways, intersections.
DaddyGlenn 09-21-2012 04:07 AM
Originally Posted by mcaterino (Post 6988515)
Glenn,
Mike
Glad you like bodywork, 'cause I frickin' hate it. I'd rather turn a wrench any day.
Regarding the gap... it may be the angle. I'll take a closer look when the sun comes up. Any recommendations on how big the gap should be pre-primer/paint?
DaddyGlenn 09-21-2012 04:08 AM
Originally Posted by maui44 (Post 6988554)
Just FYI,
Thanks for the heads up. I'll get the measurements prior to ordering.
DaddyGlenn 09-23-2012 03:00 PM
Gaps are pretty consistent all around the doors. So I shouldn't have an issue.
Took the doors off, cleaned it up, tape & paper and shot some more primer this weekend.
Next is to sand with 220.
http://forums.pelicanparts.com/uploa...1348437553.jpg
500_19B 09-24-2012 10:27 AM
Looking good! Don't forget to remove the tailight housings prior to shooting the top coats.
For the door gap, I would fashion a go/no-go gauge out of wood and size it for the gap as it is on the straight portion of the door's trailing edge. Keep the gauge narrow, and they you can use it to check the gap all the way around the curve. Looking at the picture I had the same first impression... it looks too tight around the curve. If that really is the case, then the effort to perfect it now will be well worth it, as this is the kind of thing that can grow to bug you later.
DaddyGlenn 01-17-2013 06:38 PM
Wow, its been a while since I updated this thread.
I didn't get color on the tub before the weather got too cold. It will have to wait for spring. So I've been working a a bunch of different tasks.
Cleaning the glue off the interior... work in progress
http://forums.pelicanparts.com/uploa...1358475546.jpg
Lowering and moving back the passenger side seat mount... also in progress (no pictures yet) But hey I learned something... in searching for high quality drill bits I learned that if you don't use your drill at full speed but rather let it turn slowly, the bits work better and don't overheat and lose their edge. When I think of the money I spent replacing drill bits 'cause I didn't know to go slow...http://forums.pelicanparts.com/support/smileys/wat5.gif
and the other day, I started another task... back in my comfort zone.
http://forums.pelicanparts.com/uploa...1358475877.jpg
As you can see, I have oil leakage on the right side. I can't tell for sure where it came from but I suspect a couple places. I have ordered gaskets etc to reseal the cam chain cover, the oil pressure sender and to temp sender.
It also looks like I have a leaky #8 bearing seal (behind the pulley). So that will be replaced, too.
When I first dropped the engine about 7-8 years ago, I gave it a good cleaning and fixed all the leaks in the triangle of death. I couldn't get to the bottom of the engine since I didn't have a stand at that time. I do now so I am tackling the bottom while I wait for my next Pelican shipment. Lots of gunk here.
http://forums.pelicanparts.com/uploa...1358476212.jpg
I've got about half done in the picture. Not going for perfection. Just want to be able to see if I spring any new leaks.
I'll try to document my oil leak repairs.... maybe here or perhaps another thread.
Oh, and I got another car. Picked up a 2000 BMW 740iL Sport in great shape. Wheeee :D
DaddyGlenn 01-19-2013 04:49 PM
I got the bottom of the engine cleaned and replaced the sump plate gaskets with new silicon gaskets. No surprises peeking up inside the crankcase.
http://forums.pelicanparts.com/uploa...1358642544.jpg
Then I turned my attention to the mess on the front. Got the oil lines removed and cleaned up the outside. I think my oil leak was at the block that the oil pressure sender screws into. I seemed way too loose. But I will proceed with my plan to address all suspect areas.
All clean.
http://forums.pelicanparts.com/uploa...1358642715.jpg
Then off with the cam chain cover. Everything looks good on the inside.
http://forums.pelicanparts.com/uploa...1358642845.jpg
The cam chain cover gasket was dry, no signs of oil seeping by anywhere.
