82 sc
noticed my recently aquired 82 sc one side 1/2 inch higher than the other, looking at fenders, is this a big deal worth having looked at, kind of gets on my nerves i know its there, also, this may be a stupid question, noticed when i had my lights on, the rear light or reflector thing that has porsche written on it does not light up is it supposed to or just a reflector, looked for a bulb could not see one
thanks
1982sc targa blk on blk va beach va |
Most properly corner balanced/aligned 911s will sit a bit higher on one side.
Typically, this will be the driver's side as your weight will bring the car down to even or very close. Have a friend watch the car as you enter and it'll make sense. No, the "PORSCHE" reflector does not light up. Welcome to Pelican.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Was the PO much bigger/heavier than you? If the difference is great, I would suggest having the car corner balanced and aligned with your weight in the driver's seat.
Senior Member
FWIW, I am finding out how important corner balancing is. I am doing some alignment and balancing work on my own. At one point, I had the car aligned only to find the corner balance was off. Not off by a LOT, but off by something like eighty pounds. Made a HUGE difference. The car pulled to the right and simply did not handle well. At this point in my education, I would prefer a car that is corner balanced and poorly aligned.......over a car that is aligned but poorly corner balanced.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Like SUPE stated, a properly corner balanced 911 is a treat to drive, on the track or street.
If you are happy with the car then leave it alone. Again, I would consider the weight difference between you and the PO and let that help you decide on whether it needs to be corner balanced again.
Senior Advisor
Think about going into a corner (or making a panic maneuver on the street), having 50 +- lbs. difference might cause the lighter wheel to lock, not a good situation. Very important with 4-wheel independent suspension.
08 Cayenne Turbo |
