Spartocracy
I've had my '75 911s for almost a year, and have had few problems with it. Drive it probably an average of 60-100 miles a week. On two recent occaisions, the following happened. I drove about 25 miles, then almost immediately turned around and drove straight back 25 miles back home (all highway). when I'm almost home, travelling about 60 mph on the highway, the revs go down to zero and I get no engine power, the car starts to coast, and after about 1-2 seconds, the revs go back to normal, and the engine re-engages. This happens quite a few times in quick succession until I get home. last time, it even let out a really loud backfire one time when it disengaged, then came right back online. Any ideas? Could the long highway miles just be too much, or is there something I can check? Other than this recent development, the car usually starts and runs like a dream. tia
Max Sluiter
Sounds like a heat soak issue in the CDI box. Even more likely if you have a Permatune.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Hi,
I had a similar problem, and it turned out to be a loose connection on the alternator. I believe it was the B+ connection. I also had a bad Perma-tune box years later, but it would kill on me after the car was driven then sat for a few minutes and then was restarted. The bad box did cause backfires, but I can't remember if the loose connection did. Good luck on tracking this down. I started carrying a timing light with me so that when it died I could check to see if I was getting a spark or not. -Rutager
Rutager West 1977 911S Targa Chocolate Brown |
Spartocracy
so, I'll check the alternator connections first. If the problem persists, how can I determine if its the heat soak issue, and if it is, do I just need to replace the box? Thanks.
Max Sluiter
There is a Pelican that rebuilds the Bosch CDI boxes, if I remember correctly. Ingo?
bad cdi or msd
i had a bad msd and had similar problems
1975 911S Targa Silver Anniversary Edition |
Spartocracy
Ok...so I checked the distributor, and all looks ok...I'm thinking it must be the CDI...I've got a Bosch...So what would be the consensus recommendation? Have my Bosch rebuilt, purchase a rebuilt one? Buy a new MSD? Advice would be appreciated...Also, is there any way to double check to see if my current CD box is definitely causing this issue? Thanks in advance!
Obsessed
This is a WAG from someone who barely knows anything at all but how old is your fuel filter? This sounds to me like a brief starvation issue.
I'm probably completely off base but it never hurts to start with the simple stuff... Good luck
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
Does your tachometer go to zero when the engine dies, but is still in gear turning? If so I would look at electrical, CDI, Coil, distributor points cap rotor in good shape?
Does the alternator light come on? Try driving with voltmeter hooked up and see what voltage is doing at time of cut out. If tach still reads and alternator light is out, then I would look into fuel problem.
Ed 1973.5 T |
Also make sure to check all the wire's going to coil hiding under the little black boots I had that same thing happen to me and it ended up being a broken wire where I couldn't see it till a went to replace the coil and wala there it was, also for repairs of your CDI box try ECU Repairs,Specialized ECU Repair - Porsche DME Repair, Bosch and Motronic Control Units, 1-800-328-1425, { no affiliation } I used them to do my CDI on my SC and after about 5k miles no issues his prices I thought where more then fair and since I'm in south Florida I just took it to him, I hate to ship stuff if I dont know where it's going,but for yourself or anybody else who needs a DME,ECU or CDI box I would recommend them they do other vehciles as well.
Ernie
1980sc/ Casablanca Beige 1987 944n/a White 1973E/Signal Yellow/ gone and Missed 1971T/Green/Gone 1988 944n/aWhite/Gone |
GAFB
All good suggestions above but check the points first.
Check the coil. I had this exact problem.
Spartocracy
Spartocracy
update....Finally had a chance to take the coil out and check it on a multimeter....primary showing a reading of .5, which I think is ok...the secondary is showing no continuity...So I'm assuming that means that the coil is definitely on its way out, and that's the root of my problem...sound right?
I'd still check my fuel filter and the filter at the bottom of the tank although the coil failures exhibit the same behavior
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Spartocracy
Thanks...Will-do...but if those look ok, would I be correct to assume that the multimeter readings prove that the coil is most likely the cause of my problem?
to your question, sounds likely, but could you say what connections you tested?
(from/to terminal names)
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Spartocracy
and did you check the points for dwell etc....
I would check the points, coil, all wiring before changing CDI I had this happen when the points were misadjusted and just not enough open time. I switched to a Pertronix Hall effect ignition instead of the points. Great upgrade.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Are you sure you are making good contact to the high-voltage terminal when trying to measure the secondary coil resistance? I doubt is is open since this would render the coil "kaputt"
The fact that you tachometer goes to zero when you loose power points towards the triggering. The tachometer would register with just the points opening and closing. There is only a pull-up resistor to +12V inside the CDI box that has to be functional. So in other words the tachometer is not registering spark events but trigger events. Heat soaking of the CDI box affects the SCR and causes it to short the DC/DC converter. With this failure mechanism you typically need to power-cycle the CDI box (turn the ignition off and back on) to get it to work again for a short time. As a first action clean the contacts of the CDI box, inspect your trigger wire and the points before "throwing parts" at it. Cheers, Ingo Quote:
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
