VW headlight bucket converting to H4 7inch headlight
I noticed a post using VW clear lens headlight assembly buckets to mount your 7 inch headlight units.
Question- I have a H4 fluted lens on a euro delivered 911 and it does not have the 4 x sugarscoop mount points inside the mudguards inside the headlight bucket for the Hella headlight bucket like the US cars. Did you still use the rear mounting points for your 7 inch headlight or did you mount the new 7inch headlight inside the VW bucket? I can't see from the photo. I'm worried about the weight of the headlight if I use the VW bucket mounting as I will use the new 7 inch Trucklite LED headlight and they heavier than other 7 inch H4 headlight units Any help appreciated, Markhttp://forums.pelicanparts.com/uploa...1428724607.jpg http://forums.pelicanparts.com/uploa...1428724631.jpg http://forums.pelicanparts.com/uploa...1428725021.jpg http://forums.pelicanparts.com/uploa...1428725213.jpg http://forums.pelicanparts.com/uploa...1428725268.jpg |
the h4 light mounts in the vw assembly which then mounts to the car's bucket by the tab on top and the screw on the bottom.
might be a dumb question, but will this mod work on the 964? Am I correct in thinking that the headlights in the 911 and 911 (964) are the same? I have an Australian Delivered (RHD) with H4 lights.
bump this thread. what have you all come up with in the past year?
nice
Love that the humble pre-67 VW headlight is part of this innovative Porsche 911 lighting upgrade. Very zen🤔
I'm still toying with ideas for my outlaw and was considering the 911R type side lights but seeing the clear lens idea I was wondering about mounting a side light/indicator lamp in the base below the headlamp.
There's already a hole there that needs covering and in my imagination would have the look of a 906 :D http://forums.pelicanparts.com/uploa...1486939056.jpg |
| All times are GMT -8. The time now is 08:14 PM. |
