Running lean after 30 mins
After 30 mins of motorway driving or 50 mins of local driving, my 79 euro SC starts to run lean. I can't figure why. Surely all the warm up bits are fully warm after 10 mins? Could it be a faulty AAR?
What makes you think it's running lean? Exhaust gas probe? Fuel pressure check?
If it is going lean - most likely a vacuum leak.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
I have a LM2 with wideband sensor hooked up. A great piece of kit for the CIS system.
Can't figure why a vacuum leak would only start after 30 mins of hard driving... |
Likely the WUR is too 'tight'. As it warms up it leans out by design, very common that it goes too far.
If you eliminate vac leaks, etc then maybe take a look at adjusting the WUR, but this is involved. Have you checked control pressure, system pressure?
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
Just saw your post about the a/f meter. What are your air/fuel ratios? I have a lean condition (read via a wide band 02) under load that I am scratching me head over.
At this stage I am intimate with my WUR. You are right, I could drop the control pressure a bit. Checked fuel pressures a couple of weeks ago and they were on the button. My WUR is now the adjustable type, after I got fed up stripping it every few days.
Cold: 10.5 - 11 Idle: 13.5 - 14 Acceleration: 12.5 - 13 After a good run, they change to ... Idle: 16 - 16.5 Acceleration: 13.5 - 14 So the idle gets rough and the revs drop to about 750 too. Hope this helps you. In my opinion, idle should be on the rich side ..... seems happier there. |
So why not enrich the mixture by turning the CO screw?
If I enrich, I have the following problem .....
Cold start too rich, hunting. Then after a few mins, Idle is too low and starts and hunting or stall. Hesitation on acceleration also. Am starting to think I should drop the WUR warm control pressure about 1/2 a bar and see if that helps. This should richen it a bit when warm, but not affect the cold start. |
What exactly is your warm control pressure? If you have been rebuilding a WUR, it's usually best to set the warm control pressure first by moving the position of the large plug that holds the fuel fittings. Once the warm pressure is set (and you are certain the WUR heating element/bimetallic arm is fully extended), then you can reset the cold pressure. I can't recall you mentioning your control pressures--either warm or cold--in your posts, so this would be the way to go, IMO, before touching the mixture screw.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
How do you set the warm CP without changing the cold?
Control pressure calibration......
914efi, Moving the 'block' (big circular plug) slightly down increases the warm control pressure. While moving the small plug (that holds the bi-metallic arm with heater) down decreases the cold control pressure. But it all depends on the deflection and condition of the bi-metallic arm including the heating element for the cold control pressure to be manageable. To answer your question: You can't!!!! Any movement (up/down) by the 'block' would directly affect the cold and warm control pressure settings. Before you do any adjustment, it is important to measure the cold and warm control fuel pressures. Then make the necessary adjustment as needed. HTH. Tony |
stlrj, good point.
I checked the pressures a couple of weeks ago ... Cold @ 12C - 1.5 Bar Warm - 3.3 Bar Warm without vacuum - 2.6 Bar So they should be okay - but probably worth re-checking. I have the WUR with the diaphragm and the block now has a nice little hole to let me get a 4mm allen key in at the height adjuster. Do you really think that it should take 30+ mins of motorway driving to get the WUR Fully warm? I suppose I should check that too. |
If your pressures are within spec after the 30 min run, I would start looking elsewhere, you will only be masking the problem. Look for vacuum leaks with propane at the injector sleeves and boots, the Orings are usually baked and the leaks vary with heat. If you find no vacuum leaks, I would be testing the injectors for flow.
Paul |
Fair point, thanks guys.
Just a guess.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Wur........
ZV, Check the control pressure change over time. To do this test, run the FP without the engine running. Record the control pressure reading @ start, 1, 2, 3.....5, 7,10,15,20 mins......until the control pressure stabilizes (warm). You could get the warm control pressure without running the motor just the FP. What's the heating resistance of your WUR? Do you have the correct WUR for your engine? Keep us posted. Tony |
If I am not mistaken, it should not take more than 5 mins to reach fully warm control pressure from stone cold.
Got it figured out. WUR bimetalic strip / heater is faulty. When I thought it was fully warm (like after 15 mins driving) the strip wasn't fully lifting away from / releasing the pin. It only opened fully after 45 mins of driving OR 15 mins of driving and left standing for an hour or so (I presume heat radiation from the engine keeps heating it up). So the warm start component of the WUR was running the car too lean when it had unrestricted access to control pressure tit thing in the WUR. Once re-calibrated and mixture adjusted it is pretty happy again. I don't think the solution makes complete sense as the original Lean warm start would come back into spec after running the engine for a few mins. But such is the idiosyncrasy of the CIS system.
Thanks for all the help - Again. |
