leaking transmission
Has anyone experienced leaking 915 transmission with Swepco - not 201, maybe 212 (red)
Transmission did not leak prior to disassembly. Transmission was rebuilt and when installed and run it leaked a lot. Transmission was removed and resealed and now leaks again. Minor drips start to form over 24 hours when car is parked, seems to be coming from case seals, although some appear to be coming from differential. When car is run and brought up to operating temperature it leaks badly. Just wondering if it is worth trying a different lubricant. photo of drip area from one week ago and yesterday ![]() ![]() ![]() ![]() ![]() ![]()
Carl Selden 64 356 C + 73.5 Targa -, 73.5 911 Targa - 65 356 C -,63 356 B - 75 911S Targa - |
a 915 with its synchros does not like synthetics. Why did you pick that lube? Drain it, try regular gear oil and see if it stops.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I did not pick the gear oil, it was installed by the shop who rebuilt the transmission.
Will try a different product.
Fleabit peanut monkey
I had the red SWEPCO in mine because I bought it when I did not know the difference. I think it was the 210. Get it out. Mayo Performance says it's great for gear life but not for synchro life compared to the 201.
Edit - I had some seeping but not dripping. I ran it for 10 years - um, right up to when I had the trans rebuilt. Last edited by Bob Kontak; 10-03-2010 at 06:36 PM.. |
Kinda looks like dexron auto trans fluid which alot of trans shops put in newer standard transmissions.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
oil is red Swepco 210 racing transmission oil.
