Help! Engine lid does not open!!
My engine lid won't open!!!!
I pull the engine lid latch handle and do feel very solid tension. However, the lid will not pop open.
Are there any 'emergency' manual way to open --- a la manually cranking the sunroof to open/close?
Much thanks in advance!!!!
Old 11-12-2010, 08:39 AM
kodioneill's Avatar
Have some one pull up on it while you pull the cable. If the cable is broken the lid should pop up.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-12-2010, 08:42 AM
Zeke's Avatar
As is usually posted, drive on an unlevel surface flexing the car while pulling the cable. One wheel up a curb or something like that. Go both ways.
Then take time to find out how to adjust the plunger.
Old 11-12-2010, 08:59 AM
Thanks for quick reply!!! I will try that tonight.
If cable is broken, I suspect PP will carry that part --- what's involved to replace it??? Massive removal of interior trim?
kodioneill's Avatar
I think you slide it through a metal tube that is welded in place that terminates at the latch.
1982 chiffon 911sc
Old 11-12-2010, 09:06 AM
D911SC's Avatar
Tube runs through LH rear wheel well - along the top but on the inside of fender. You can see it come out of the back of the door post panel.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 11-12-2010, 09:10 AM
Yes --- where the latch handle is located.
Any idea if new cable s/b 'threaded' starting from the latcg handle, or from the engine cimpartment side?
Thanks to all for your knowledge!
Old 11-12-2010, 09:51 AM
kodioneill's Avatar
Plastic "T" handle fixed to a wire that is connected by a set screw to a barrel at the latch.
1982 chiffon 911sc
Old 11-12-2010, 10:09 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you change the cable...remember to grease the heck out of it as you push it into the tube.
Bob
Bob Hutson
Old 11-12-2010, 11:27 AM
