Originally Posted by BBShriver View Post
Thanks for the diagram. From that though it looks like you're effectively bypassing the ignition switch altogether and would not require a key at all. Is that correct?
The added switch circuit only bypasses the "start" or "crank" position of the switch. The ign. switch must still be in the "ON" position to activate the ignition system.
Sherwood
Old 10-10-2010, 03:02 PM
Well, I've got the new starter, hot start relay, and ignition switch on order.
In the mean time I want to go through and check the contacts, etc. Where are the critical contacts for the starter going to be located in a 73?
Pictures would be helpful.
B Shriver
http://foremostcarguy.blogspot.com/
Old 04-14-2011, 12:36 PM
