How Do You Replace the Tiny Rubber Fuel Line in a 1988 Carrera?
Over the winter I replaced the fuel line that goes across the rear of the motor (closest to the interior) and the one that has a metal center in a kind of "H" shape. I have the small little "expensive" fuel line that I could not reach or get to. It goes on the drivers side of the motor in the corner in the rear. Is there a trick to replacing this without removing the motor?
Jack
1988 Carrera Cabrio
Old 07-14-2010, 11:38 AM
take off the heat blower for more access. about $175 from the dealer.
206 637 4071
Old 07-14-2010, 12:41 PM
Are you saying that even though I have the hose the dealer charges $175 labor?
Jack
Old 07-15-2010, 12:47 PM
Senior Advisor
James Brown's Avatar
Sounds about right.
08 Cayenne Turbo
Old 07-15-2010, 01:01 PM
Thrlls's Avatar
I was told the manifold would need to be removed for better access, so when I did my engine drop I changed out ALL my fuel lines.
That little "J" hose is a PITA to get to without an engine drop/lower.
However, if your arms are thin enough and you can stay in a contorted position for a long period of time, you may be able to do it without a drop or manifold removal.
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 07-15-2010, 01:15 PM
rnln's Avatar
if you can find a picture of the area back there, you can do it with feeling by your fingers. I did it with this method before I first seen any pic, was hard but doable.
Fat butt 911, 1987
Old 07-15-2010, 03:40 PM
Jack
$175 for the hose. it would be easy to make one up except for the preformed hose part.
$160 from pelican. 930 110 509 01
206 637 4071
Old 07-15-2010, 04:44 PM
Throw it on the ground!
Or, you can send it out for a rebuild for a fraction of the cost (probably $25 max in braided stainless)
Fuel lines sent to Amazon Hose Tampa for rebuild
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 07-15-2010, 08:08 PM
Mark,
Great pix and I thank you! I just can't reach it. I have a bum back and a very limited use right shoulder.
If my H fuel line started leaking at a crimp and I replaced that .I also replaced the fuel line that goes from one fuel rail to the other. Do you think that I can drive out the summer in my 88 not replacing the tiny line? I have a new one in my trunk I bought from Porsche in case I get stuck on the road.
Should I give it one more try or bring it into Porsche or a small Porsche shop?
I have found that by doing all myself it gets done right. In my limited condition, a job that might take you 5 hours will take me 2 weeks. But it gets done.
I just wish that I could reach it from under the car.
Jack
Old 07-16-2010, 06:22 AM
at least get a mirror and flashlight back there for a good look. they tend to get cracks in the inner curved portion.
206 637 4071
Old 07-16-2010, 07:44 AM
rnln's Avatar
I would drive any car with leaking fuel. I love to eat BBQ but don't want to be BBQ.
another thought, if manufacture use clamp on one end, can we use clamp on both ends?
Fat butt 911, 1987
Old 07-16-2010, 10:24 AM
If I can't get to it I will speak to a PORSHE mechanic and pay for him to do it for $100. cash. I will remove the top intake for him. If not I will bring it in, as it still is cheaper than replacing an 88 Carrera with only 15k.
Jack
Old 07-16-2010, 03:48 PM
AlfonsoR's Avatar
I was doing research on how to do an engine drop to repair an oil leak and also researching what are the "while you're in there" things I need to do.
Thanks for the great pics MThomas58!!
Old 10-12-2010, 02:07 PM
burgermeister's Avatar
I find it interesting that it comes with a widely poo-pooed fuel injection clamp (not crimp) from the factory! It is the return line of course, but still ...
FWIW 3 months later, I just dropped my engine, and my front (near pass compartment) fuel line is filled with lovely cracks, but all the others including this short one still appear sound.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 10-13-2010, 02:28 PM
NOS? (New Old Stock)
Mark
1987 911 Coupe
Old 10-13-2010, 02:37 PM
