What could cause a slow clock?
It's not that the clock in my '76 doesn't work, it's that it's either running slow or running intermittently. figuring the problem was with that particular clock, i bought another one, used, from a vendor here, who said he tested it, and this one does the same thing. crap. so, if it's not the clock, what else could it be ... and how can i fix it?
thanks!
Old 10-13-2010, 04:25 AM
Have you been driving near the speed of light?
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 10-13-2010, 04:36 AM
chris 964's Avatar
Theory of Relativity - Technically its called "time dilation" the higher above sea level you are the faster clocks run. So are you below sea level?
Could be just bad luck with the 2nd clock
Old 10-13-2010, 05:24 AM
The clock in my '72 has a screw adjustment on the back side.
Steve B.
1972 911t
1999 328is
Old 10-13-2010, 05:35 AM
floete: My clock runs slow too........I fixed mine by setting it about 4 mins ahead everytime I drive it.....I'm a pretty good mechanic.
73 911T MFI Coupe, Aubergine
Old 10-13-2010, 06:01 AM
That was my first thought as well.
Old 10-13-2010, 06:30 AM
Drisump's Avatar
Thats what I was thinking....
Old 10-13-2010, 07:09 AM
I've had a similar problem with the clock in my 73, though not as pronounced as yours. It keeps perfect time but occasionally, I'll notice it's lost 5-10 minutes. This is very intermittent, like once every two to three months so I haven't really bothered to trouble shoot but I suspect something in the clock itself rather than the wiring. My guess is something is amiss in both clocks you have. The second, used clock, most likely was tested by the seller but unless it was run continuously for many hours the fault didn't show up. The only other possibility is the fuse which controls the circuit (as well as the dome lights and glove box light) may be corroded a bit and there is an intermittent loss/drop of voltage--something you wouldn't notice from the other items on the circuit.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-13-2010, 07:26 AM
Senior Member
Have you guys ever taken the clock apart, or the back off?
Not in this 911 but my 1972 model had this happen at times. Took the back off and found that the points were burned. There is a set of points that make or break contact to rewind the spring. Took a small point file and cleaned them up and the clock worked great from then on.
Might give this a try... unless its a completely electronic clock.
Joe A
Old 10-13-2010, 07:38 AM
MBEngineering's Avatar
HI Guys
have a look hear about your clock's;
DDK - Die Deutschen Klassiker :: View topic - How to Repair Your Clock
and see if yours are the same?
regards mike
Old 10-13-2010, 08:25 AM
porsher
aston@ultrasw.c's Avatar
or close to any black holes?
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 10-13-2010, 11:41 AM
Joe A
The clock in his 76 is completely electronic, I believe, and so is the one in my 73, though it may be a replacement--not sure when the changeover was made.
If the clock face reads, "Kienzle" just above the 6, it has the points as described. If it reads, "Querz-Zeit" it is electronic.
L.J.
Old 10-13-2010, 05:28 PM
hey
Maybe you need to get your clock cleaned! Nick
Old 10-13-2010, 08:27 PM
nick: har!
others: thanks for weighing in. i'm going to attach the clock directly to a 12v battery today and see what time it tells after a few hrs; that ought to rule in/out the clock itself.
Old 10-14-2010, 04:07 AM
dshepp806's Avatar
may be some plenty old electrolytic caps that are wasted...then again, I;ve never studied that circuit
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 10-14-2010, 02:54 PM
My clock in my 85 carrera works fine with you are driving but when it sits off, it stops after about 5 hours! I checked the voltage with my meter at the clock and it reads over twelve volts. Also when you are driving it keeps perfect time which seems to say it does not need to be cleaned. Very strange these Porsche clocks! I changed the fuse, cleaned the contacts. Maybe a past owner died and is just messing with me. Nick
Old 10-14-2010, 07:47 PM
AutoBahned
RWebb's Avatar
my clock slows down in the winter
Old 10-14-2010, 08:58 PM
Carrera Cab Connoisseur
nyne11's Avatar
ummmmm....A slow clock!
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 10-16-2010, 04:02 AM
update -- more help needed.
hooked the replacement clock up to the car's battery directly and it ran slow, so figured i had two slow clocks and sent the just-bought one back to the seller. he hooked it up to his power source and, yup, you guessed it, the thing kept perfect time.
so ... could it be a problem with my battery? if so, what could it be and what can i do about it, besides nothing?
tia!
Old 10-21-2010, 05:27 AM
