71T 71T is offline
71T's Avatar
Bilstein HD Question
I'm looking to upgrade my stock suspension on the T and I'm thinking about going with used parts.
Bilstein rear shocks are listed as two different part numbers. One for 71 and earlier and one for 72-89. What is the difference? What years can I use?
I've heard Bilstein will rebuild/revalve their shocks. How much does this service cost?
Colin
'71 911T
Old 10-14-2010, 06:44 PM
Max Sluiter
Flieger's Avatar
The 70-71 crossmember is a unique design and requires a different sized damper than the later or earlier cars. The 1972- cars can use Aluminum rear trailing arms, the 1970-1971 cars run into rubbing issues of the damper on various exhaust areas or crossmember areas. I suspect that the later dampers may bind the suspension on a 1971 when the suspension moves through large displacements.
Old 10-14-2010, 07:06 PM
Chuck Moreland's Avatar
Max is correct the crossmember is different on the pre-72 cars.
The specific differences in the shocks:
- pre-72 are shorter
- pre-72 have M12 lower mount, 72+ have M14 lower mount
- different valving
It is possible to use the Al arms on an early car, but mods are needed - and you may still have a bit of rubbing. But it is doable.
Chuck Moreland - elephantracing.com - vonnen.com
Old 10-14-2010, 08:58 PM
