What could cause a slow clock?
It's not that the clock in my '76 doesn't work, it's that it's either running slow or running intermittently. figuring the problem was with that particular clock, i bought another one, used, from a vendor here, who said he tested it, and this one does the same thing. crap. so, if it's not the clock, what else could it be ... and how can i fix it?
thanks! |
Have you been driving near the speed of light?
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
Theory of Relativity - Technically its called "time dilation" the higher above sea level you are the faster clocks run. So are you below sea level?
![]() Could be just bad luck with the 2nd clock |
The clock in my '72 has a screw adjustment on the back side.
Steve B. 1972 911t 1999 328is |
floete: My clock runs slow too........I fixed mine by setting it about 4 mins ahead everytime I drive it.....I'm a pretty good mechanic.
Steve 73 911T MFI Coupe, Aubergine |
That was my first thought as well.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I've had a similar problem with the clock in my 73, though not as pronounced as yours. It keeps perfect time but occasionally, I'll notice it's lost 5-10 minutes. This is very intermittent, like once every two to three months so I haven't really bothered to trouble shoot but I suspect something in the clock itself rather than the wiring. My guess is something is amiss in both clocks you have. The second, used clock, most likely was tested by the seller but unless it was run continuously for many hours the fault didn't show up. The only other possibility is the fuse which controls the circuit (as well as the dome lights and glove box light) may be corroded a bit and there is an intermittent loss/drop of voltage--something you wouldn't notice from the other items on the circuit.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Senior Member
Have you guys ever taken the clock apart, or the back off?
Not in this 911 but my 1972 model had this happen at times. Took the back off and found that the points were burned. There is a set of points that make or break contact to rewind the spring. Took a small point file and cleaned them up and the clock worked great from then on. Might give this a try... unless its a completely electronic clock. Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
HI Guys
have a look hear about your clock's; DDK - Die Deutschen Klassiker :: View topic - How to Repair Your Clock and see if yours are the same? regards mike |
porsher
or close to any black holes?
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
If the clock face reads, "Kienzle" just above the 6, it has the points as described. If it reads, "Querz-Zeit" it is electronic.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 10-13-2010 at 05:44 PM.. |
hey
Maybe you need to get your clock cleaned! Nick
nick: har!
others: thanks for weighing in. i'm going to attach the clock directly to a 12v battery today and see what time it tells after a few hrs; that ought to rule in/out the clock itself. |
may be some plenty old electrolytic caps that are wasted...then again, I;ve never studied that circuit
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
My clock in my 85 carrera works fine with you are driving but when it sits off, it stops after about 5 hours! I checked the voltage with my meter at the clock and it reads over twelve volts. Also when you are driving it keeps perfect time which seems to say it does not need to be cleaned. Very strange these Porsche clocks! I changed the fuse, cleaned the contacts. Maybe a past owner died and is just messing with me. Nick
AutoBahned
my clock slows down in the winter
Carrera Cab Connoisseur
ummmmm....A slow clock!
Dave 1986 Carrera Wide Body Cabriolet 1993 Nissan 300ZX Twin Turbo (620rwhp) 2003 BMW 330Ci MSport Individual 1973 Mercedes 350 Custom Convertible |
update -- more help needed.
hooked the replacement clock up to the car's battery directly and it ran slow, so figured i had two slow clocks and sent the just-bought one back to the seller. he hooked it up to his power source and, yup, you guessed it, the thing kept perfect time. so ... could it be a problem with my battery? if so, what could it be and what can i do about it, besides nothing? tia! |
