Formerly known as Syzygy
Canada Kev's Avatar
G50 transmission gearing question
My 1987 Carrera is an ROW example. Is there a possibility that it may have different gearing than one from North America?
Kevin
Old 10-22-2010, 12:18 PM
gearhead
Yes, it is possible. If you crawl under the car you can see if you have a G50/00 or a G50/01
G50/00= 3.5, 2.059, 1.409, 1.074, 0.861
G50/01= 3.5, 2.059, 1.409, 1.125, 0.889
Both have a final drive of 3.44
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-22-2010, 12:23 PM
Canada Kev's Avatar
Thanks, Matt. I'm going to be doing an oil change today, and just so I don't spend forever under there looking around, where would I find the number?
Kevin
Old 10-22-2010, 12:33 PM
Bill Verburg's Avatar
The # is on the bottom of the trans, this is my G50/30
for '87 there were 3 G50 versions
G50/00 was used in Europe and most of the rest of the world
G50/01 was used in US and Japan
G50/02 was used in Switzerland
Matt posted the ratios for the 1st 2, the /02 is 3.154, 1.895. 1.333, 1.036, 0.861 again w/ 3.444 cwp
Bill Verburg
Old 10-22-2010, 12:53 PM
KTL KTL is online now
Schleprock
KTL's Avatar
If you have an /02, congrats. Its the only of the three that has decent gearing. The others are rather poor for spirited use (ie track). If you like 0-60 sprints, /00 and /01 are not so bad. However their gear spacing rather stinks for track use IMO. On a fairly long fast track, you've basically got a two speed transmission and only occasionally would hit 5th. Overdrive 5th is not for putting down power, but for dropping revs to retain decent gas mileage.
Also check your serial number as Bill indicated for a #2 between the G50/## designation and the production #. The 2 indicates it was originally fitted with a limited slip differential.
Kevin L
'86 Carrera "Larry"
Old 10-22-2010, 01:11 PM
AlfonsoR's Avatar
Good info, thanks guys.
Old 10-22-2010, 01:24 PM
Canada Kev's Avatar
OK, after rolling around on the ground for a bit, these are the only numbers I found on my tranny. Is the 950/02 really mean G50/02? This would make sense as it was a Swiss car, though I don't know off the top of my head if it originated there. I'd have to check the records.
I have no idea what all the other numbers mean, and it looks like the thing was stamped again with the 73H...
Kevin
Old 10-22-2010, 05:25 PM
Diss Member
Quicksilver's Avatar
A 950 is a G50. A lot of the early G50s were 950s. People just call them G50s.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-23-2010, 06:52 AM
Canada Kev's Avatar
Cool. So it's a G50/02, then. I can live with that. The gear ratios in driving seem pretty good to me. The numbers between this and the /00 and /01 suggest quite a difference in first gear. I never thought that mine was rather tall in first. In fact, it seems about right or maybe I'm just used to it...
Thanks for the info.
Kevin
Old 10-23-2010, 01:03 PM
Originally Posted by syzygy View Post
Cool. So it's a G50/02, then. I can live with that. The gear ratios in driving seem pretty good to me. The numbers between this and the /00 and /01 suggest quite a difference in first gear. I never thought that mine was rather tall in first. In fact, it seems about right.
here's a comparison of most 5 spd G50s
Bill Verburg
Old 10-23-2010, 02:18 PM
Schleprock
KTL's Avatar
For future reference if this comes up in somebody's search, like Wayne said the initial run of G50's circa 1987 had 950 instead of G50 in the serial number. Seems in '88 they changed the stamping to say G50. The H in your serial number indicates 1987 production year. J is 1988, K is 1989 and so on. I and the letter O are typically skipped to avoid confusion with #'s 1 and zero (0)
Kevin L
'86 Carrera "Larry"
Old 10-23-2010, 02:22 PM
