-   -   Engine Drop: While you're in there stuff?? (http://forums.pelicanparts.com/porsche-911-technical-forum/571370-engine-drop-while-youre-there-stuff.html)
AlfonsoR 10-23-2010 05:25 PM
Guys,
I am planning an engine drop (first one) to replace the oil cooler seals, they are leaking and oil from that and from leaky fitting on oil return line is getting onto exhaust, so those are the main two reasons for the engine drop. But can you guys help me with other stuff to replace "while i'm in there"?? The car is an 89 Carrera 3.2 and has 104,000 miles. Valve guides were replaced at 98,000. I will be dropping engine and trans as one unit. This is my list so far:
1. throttle bell crank bushings, on engine and trans
2. three fuel hoses and oil return line to Amazon hose in Tampa, c/o Bill Hippy
3. oil cooler seals
4. oil pressure sending unit
5. Spark plugs
6. valve lash adjust
7. Transmission oil
What else??
Thanks in advance. ;)
Oh Haha 10-23-2010 05:31 PM
Engine and transmission mounts although they can be done with the engine in.
Zeke 10-23-2010 05:45 PM
How's the sound/heat pad?
86 911 Targa 10-23-2010 05:59 PM
Fuses and relays
Not part of your ongoing effort(s),
but check my June post "Adding fuses and relays".
And +1 on your sound heat pad.
P/N 911-556-891-01
Good luck,
Gerry
longhornchris04 10-23-2010 06:47 PM
Vac lines & heater hoses, especially if they look at all worn.
++ on the sound mat, very easy without the engine... very hard with.
I'm not familiar with the 3.2 engine bay layout, but in the SC/2.7 the fuel filter is much easier to deal with w/o the engine in (unless the electric heater fan has been removed), and you don't spill gas all over the engine.
Jerome74911S 10-23-2010 07:01 PM
I replaced the sound pad, as some others recommend.
Got a deluxe one from our host:
http://forums.pelicanparts.com/uploa...1287885510.jpg
Honestly, I don't notice any improvement in noise abatement when compared to the original - and disintegrating - noise pad. But, it needed to be changed, regardless.
JJ 911SC 10-24-2010 03:29 AM
Start Ordering...
Doing the same and looking for a "not going crazy" list... Got the sound pad last year so it will go in.
101 Project #7 highly recommends the following replacement among other things;
Oil Pressure Switch: Project 21
Heater Hose: Project 43
Oil Breather Hose: Project 21
Clutch and Flywheel seal: Project 8
CIS Intake Manifold Hose: Project 31 (1973-1983)
Oil Cooler Seals: Project 21
Pulley Seals: Project 21
Valve Cover Gasket (& adjustment): Project 18
Oil Cooler O Ring Thermostat: Project 21
Rocker Arm Seal: Project 21
mthomas58 10-24-2010 06:01 AM
Be sure to check the condition of the rubber on this vacuum line behind the heater blower as cracking is a common failure. Link to my repair thread attached.
http://forums.pelicanparts.com/porsche-911-technical-forum/428782-repair-vs-replacement-options-part.html
http://forums.pelicanparts.com/uploa...1287924978.jpg
http://forums.pelicanparts.com/uploa...1287925199.jpg
sp_cs 10-24-2010 06:47 AM
Banana arm bushes?
Fuel line inspection, for sure
yelcab1 10-24-2010 07:05 AM
and if you are close to replacing it, then replace the clutch. If you do go into the clutch, replace the rear main seal as well.
Oh Haha 10-24-2010 07:12 AM
+1000!!
yelcab1 10-24-2010 07:18 AM
cleaning and paiting engine tin baffles. that is almost free.
mppickett 10-24-2010 11:29 AM
Check the oil breather gasket to see if it is leaking. If you're replacing the clutch, be sure to put in a new release bearing.
burgermeister 10-24-2010 12:25 PM
You can de-rust & refurbish the heater flapper valves.
Rear brake lines are a breeze with the engine out
Rear wheel bearings are a lot easier
silverc4s 10-24-2010 12:45 PM
Originally Posted by sp_cs (Post 5632291)
Banana arm bushes?
Not sure what year your car is, but on many of our torsion bar cars, the bolts that hold the banana arms in place are installed pointing outward. Reversing these - as you check the bushings - will enable removal with the engine in place in the future.
Also a good time to clean and repaint or powdercoat all of the engine tin. Nice dress up item...:cool:
AlfonsoR 10-24-2010 12:54 PM
Thanks guys for all the replies…
Let’s see
Engine and trans mounts → will check these once engine is dropped, thanks Wayne
Sound/heat pad → looks to be in good condition. I will take a closer look once engine is down, thanks Milt
Fuses and Relays → this one’s been at the back of my mind. I definitely don’t want my car to burn down to the ground, so I’ll probably do this too, thanks Gerry
Vac Lines & heater hose → I guess I’ll have to search on that one, not sure where these are
Fuel fitler → thanks for reminding me of that. I actually already have the filter, thanks Chris
101 porjects → I’ve been meaning to buy this reference. Thanks for the list JJ. I too did not want to go Crazy with this project.
Vacuum line → thanks MThomas,
Bannana Arm bushings, need to research these too → thanks Shirish
Clutch → The clutch feels good, if a bit stiff for a hydraulic unit. So won’t be replacing it now. Thanks YelCab1
Clean and paint engine compartment → will do, thanks again YelCab
Oil Breather gaskets → thanks Mike, I will do these too
Flapper valves → will do, thanks Burgermeister
Reverse Banana bolts and powder coat engine tin → thanks Bill
Thanks again everybody!!
gregwils 10-24-2010 05:54 PM
I'll suggest the temp sensor and the speed and reference sensors. If the outer casing on your sensors crumbles in your hand, time to go. You can cross reference the speed and ref sensors to BMW units which are considerable less expensive (1/2). I don't have the part numbers, but there are threads that list them. I did mine two years ago with Bosch units for a BMW. They were identical in every respect - length, bolt location, diameter, etc. Direct replacements from the same manufacturer designed for a motronic engine mgmt system.
euro911sc 10-24-2010 06:19 PM
With the engine out it is a good time to check CV joints and boots for wear and tear.
-Michael
Tom Macy 10-25-2010 07:37 PM
Engine out-------Clean Clean Clean make it spotless and keep it that way.....
Polish or look into the fan and alternator assembly, any seal and or o rings
valve cover gaskets, fuel lines disinigrate, change them. Steam clean.
Clutch throw out bearing new disk, and your car will really quiet down...
Have fun
Tom
88 Carrera Targa
mthomas58 10-25-2010 07:59 PM
+1 on replacing speed, reference and CHT sensors. Easy to do with engine out and good preventative maitenance. I am going thru a no start situation traced to a reference sensor failure right now.
