ASE Master Tech - 35 yrs
larrym's Avatar
Question 3.2 DME - idle adjusting - per Sept Pano
OK - it was a great September Pano article by Alan Caldwell on getting stable idle on 3.2 dme cars
- but - we guys with 3.2 conversions REALLY need to know - - the rest of last paragraph
what are those secret jumper settings that allow us to bypass the O2 sensor requirement?
- where is that info besides in the nearly unobtanium factory manual which most of us conversion guys do not posess or have access to ?
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 10-08-2010, 08:00 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Here ya go............
Inside the engine compartment relay cover.
And, check my thread of 10/3/2010. "Another Idle Issue"
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-08-2010, 08:34 PM
MH911's Avatar
Hmmm. I didn't get my September issue. I'm very interested in this article.
Kipp
1987 Black 911 3.2 Carrera Coupe
1999 Green Mazda MX5 (SOLD)
Old 10-08-2010, 09:22 PM
What is that socket used for normally? I've always looked at it and thought something needs to be plugged in there.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-09-2010, 09:18 AM
The jumper only disables the icv, which would compensate for the idle screw adjustment by letting more or less air past the throttle. To disable the O2, you merely disconnect it, as when adjusting CO%.
Old 10-09-2010, 09:48 AM
MH911's Avatar
Well, my Sept. issue arrived yesterday. I read through the article and it seems simple enough to do for a very low experienced wrench like my self. So, where can I locate one of these exhaust system analyzer and am I going to pay an arm and a leg for one? Is it something one can rent? Is there another way to take this reading?
Why am I looking into this?
I have a idle surging issue when engine is hot. When I disconnect the O2 Sensor, then the engine will idle just fine. My mechanic said that the O2 sensor I replaced in April was defective. I have the old one installed now ( still surging ) and waiting for a replacement for the defective one. I would like to get a proper adjustment after the replacement O2 sensor is in place.
Thanks everyone for any help on this issue.
Kipp
Old 10-10-2010, 10:09 AM
Hot surging can be a vacuum leak.
You might want to rent or borrow a co% meter. The mixture adjustment only applies to cold startup. Once in closed loop, really there is no adjustment.
Old 10-10-2010, 10:53 AM
RSM-M491's Avatar
I did the idle adjustment today, question, when I put the jumper in place the car started to idle roughly. Is that normal? I also had to turn the screw a good amount to get the idle to change!
(Counter clockwise)
Thanks!
Rod
1989 911 Targa M491
1980 Triumph TR8 (sold)
2006 BMW M3 (Interlagos Blue)
Old 10-10-2010, 01:16 PM
MH911's Avatar
I'll start looking for a leak when I get the replacement O2 sensor installed.
In the mean time, I'll be using my search button on how to find leaks. :-)
Kipp
Old 10-10-2010, 07:26 PM
I would try to find the leak first. The reason is that if you find and seal off vacuum leaks, then the surging will go away, and you'll find that the O2 sensor is good. The reason surging stops when you disconnect the O2 sensor is that it's running in open loop, on a preloaded map. No surging because the dme is not measuring false air.
Old 10-10-2010, 07:49 PM
RSM-M491's Avatar
I tried to adjust the idle this weekend, waited for the car to warm up, put the jumper in, and turned the screw counter clock wise, I gotta tell you, not sure it really worked! Could there be another issue? Also, when I put the jumper in place it started to idle even rougher! SHould it do that when I hook in the jumper?
Also, my throttle cable seems to be sticking sometimes, lubed everything under the rear deck, any other suggestions? Or do I need a new cable?
THANKS!
Rod
1989 911 Targa M491
Old 10-11-2010, 08:56 AM
See if the icv is resting in the half open position.
Old 10-11-2010, 09:20 AM
RSM-M491's Avatar
Ok, HOW do I do that? I am new at this, so I apologize. I am great on British cars, but learning my away around on the 911.
Thanks!
Rod
1989 911 Targa M491
Old 10-11-2010, 09:45 AM
an observation
The article in Pano on the idle adjustment was good as far as it went. It did not emphasize the following though.
A very basic assumption prior to setting the idle (i.e.making final idle adjustments) is that all other aspects of your engine and related systems are operating correctly, within acceptable ranges.
For example:
The state of tune should be good, including valves properly adjusted and cam timing correct and of course, reasonable compression and low cylinder leakage.
Other fuel injection components functioning correctly - especially, not to overlook the head temperature sensor and be on the lookout for vacuum leaks. System fuel pressure is also critical.
The explanations contained in this article are fairly good, as far as they go. The big problem I see is that idle problems are not always related to idle adjustments.
Old 10-11-2010, 10:28 AM
I think it might help to post excerpts from the article at this point for clarity. Too much clouding of the issues going on here.
Old 10-11-2010, 11:49 AM
RSM-M491's Avatar
Any idea as to why when I put the jumper in, the idle got more rough?
Thanks!
Rod
1989 911 Targa M491
Old 10-11-2010, 06:13 PM
My 3.2 idle seems to do the same
Hi. I have a 3.2 ,I live in Australia. My car starts first time every time. But idle surges approx 10-15 times when started, I assume until it gets warm, then it settles to around 1000rpm. After driving for some time it seems to do the same thing when I stop at traffic lights. Most of the time I give the accelerator a rev and the engine settles to around 1000 revs . I have changed the O2 sensor and fiddled witht the idle but no change. I am going to change the head temp sensor as well (just arrived from Pelican) but I don't think this will work as most of what I read says that if this unit is faulty it usually only affects cold starts, engine won't start ? Anyway I will give it a go and let you know what happens.
Old 10-24-2010, 03:19 AM
Friend of Warren
I suspect there are going to be a few 3.2's then end up running worse then they did before people read this article.
Kurt V
Old 10-24-2010, 06:02 AM
kodioneill's Avatar
The air flow meter can cause problems. Do a search for adjusting the AFM. There is a potentiometer inside that can wear out and a small adjustment that can be made to correct it . Also to check for vacuum leaks, spray small spurts of brake clean around the intake manifolds and see if the idle changes. My injectors were bad and I replaced them it made a world of difference.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-24-2010, 06:52 AM
Could be a vacuum leak. Check the hoses and intake gaskets.
Old 10-24-2010, 09:05 AM
