Turbo headers worth the trouble?
I have had a beautiful set of GHL headers (w/heater boxes) sitting in my attic now for 3 years (impulse buy). I have not installed them because I have questioned if the factory 965 exchangers are nearly as good.
What should I expect from installing these. Here is a description of my car. 1982 911sc narrow body @2675 lbs with out me in it. Engine is a a factory 965 3.3 Turbo S engine (rated @370hp) The turbo S engine has different cams and heads. I dont recall if its the same turbocharger but recall its a K27 7200. I added a modified fuel distributor and run the boost at 1.2 bar with excellent a/f ratios and exhaust temps. Aside from the fuel distributor the entire engine is stock. Of course the 965 muffler and cat were swapped out for a large single outlet stainless B&B muffler. Waste gate has an open down pipe. The transmission is a 1987 G50 box with very short gearing. Full boost comes in around 3000 rpm with current configuration. Will I get any worthwhile reward from installing these GHL headers? Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
You SHOULD see an improvement based on the headers being more free-flowing but I would post this in the 930 forum. Those guys can probably tell you exactly how many HP/TQ you will gain and at what RPM they will show up.
![]() edit-nevermind, you already did.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne Last edited by Oh Haha; 10-31-2010 at 08:34 AM.. |
Kurt,
the headers should lower boost onset by 6-800 RPM. Moreover, you should gain serious torque throughout the power band. Real world horsepower improvement would be 15-20 despite what B&B would have you believe. Bolt em up...
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
more PM's than Posts
Engine is a a factory 965 3.3 Turbo S engine that sounds fun! |
