pjv911's Avatar
Send a message via AIM to pjv911
Turbo headers worth the trouble?
I have had a beautiful set of GHL headers (w/heater boxes) sitting in my attic now for 3 years (impulse buy). I have not installed them because I have questioned if the factory 965 exchangers are nearly as good.
What should I expect from installing these. Here is a description of my car.
1982 911sc narrow body @2675 lbs with out me in it.
Engine is a a factory 965 3.3 Turbo S engine (rated @370hp)
The turbo S engine has different cams and heads. I dont recall if its the same turbocharger but recall its a K27 7200.
I added a modified fuel distributor and run the boost at 1.2 bar with excellent a/f ratios and exhaust temps.
Aside from the fuel distributor the entire engine is stock. Of course the 965 muffler and cat were swapped out for a large single outlet stainless B&B muffler. Waste gate has an open down pipe.
The transmission is a 1987 G50 box with very short gearing.
Full boost comes in around 3000 rpm with current configuration.
Will I get any worthwhile reward from installing these GHL headers?
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 10-30-2010, 08:28 PM
Oh Haha's Avatar
You SHOULD see an improvement based on the headers being more free-flowing but I would post this in the 930 forum. Those guys can probably tell you exactly how many HP/TQ you will gain and at what RPM they will show up.
edit-nevermind, you already did.
Pacific Blue
Wayne
Old 10-31-2010, 07:19 AM
rsrfan's Avatar
Kurt,
the headers should lower boost onset by 6-800 RPM. Moreover, you should gain serious torque throughout the power band. Real world horsepower improvement would be 15-20 despite what B&B would have you believe.
Bolt em up...
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 10-31-2010, 08:06 AM
more PM's than Posts
NY91184's Avatar
that sounds fun!
Old 10-31-2010, 08:55 AM
