80 911 SC, Orem, Ut
High Beam Low Beam - Turn Signal
I haven't much at night in my Porsche since I got it but tonight I noticed that my high beams are on all the time, except when my turn signal is on.
When I put the turn signal on the lights dim. Turn signal off, High Beam. When I click the high low switch in goes to low if I hold it in position. I presume this means the switch is bad. Is it worth trying to repair or is is just a replacement item.
Rob 1980 911 SC |
My journey... '68 912, '80 911 SC Targa, '91 964 C2, '93 964 C2, '95 993 (my favorite!), '04 Alpina B3 3.3 (ex Damon Hill's personal ride), '99 996 C2 Cab, '02 996, '87 Carrera Coupe, black on black... Gorgeous. Currently: triple black 08 C4 Cab and on the lookout for an early Longhood project.....
Need a new switch i have one $75.00 shipped regards tom
Flat Six
+1 turn signal switch.
Headlight relays should be next upgrade so you don't have to replace it again. BTDT Dale
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
You don't *need* a new switch. A lot of the time, you can fix the old one. I fixed mine a number of years ago and no problem since. I have since also added the relays.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
80 911 SC, Orem, Ut
Thanks for the info. I'll try the fix first.
Won't get to it until spring. But probably won't drive much at night due to the pending winter weather. Thanks.
Rob 1980 911 SC |
Senior Member
Check your fuse box for a spare (empty) slot for the Marcus Sucro or similar upgrade - a relay for your hi/lo. A must have. The stalk switch can be repaired - be sure to lube with non-conductive grease (i.e. not dielectric).
'78 Targa in Minerva Blue |
No doubt, integrate the relay mods into your exercise.......switch? Fix or replace.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Does anyone have advice on replacing the entire stalk unit? My stalk handle is badly worn and I was told to replacece the entire unit vs. the stalk only. looking for directions. Thx!
Remove steering wheel; Remove clam shell; Note how the wires are routed; Remove old switch assembly but leave wires attached; Remove the wire bundles that go to the sockets in the fire wall, route the new wire along the same path, and plug in new wires; For the wires going to the ignition switch, they are individually attached to the switch. I removed them one at a time and replaced it with the new wire before removing the next wire; Replace Clam Shell; Replace Steering wheel; Install relays.
