83 911 Production Cab #10
Oil Pressure Sender Question (with Pics)
I'll be replacing mine shortly. I was surprise how small the hole is...
Anyway, I got a couple of questions; * does anybody got a source for the connector that goes on top of it, mine is crack. * what do you use to torque it down, a crow feet? Thanks ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Not to answer all your question in specific, but this might help. I can't remember every single detail but hope someone mentioned it in the thread.
Question on replacing the oil pressure sender
Fat butt 911, 1987 |
Member 911 Anonymous
The connector is part of the main wiring, so you will need to re-build/glue back the connector or do as SLODAVE and crimp an aligator clip or as other's suggested just solder a female bullet connector and put some marine heat shrink on her.
Hey Rnln, Get back to work!!!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Throw it on the ground!
Best to remove the block that it is mounted to and remove/ replace with new sender on the bench vs in situ. See pics in attached thread. Another Oil Pressure Sender Replacement Thread with pics
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Thank Guys
The engine will be out so it will be some what easier. Earlier in the year I ran a while with an alligator clip just to confirm the needle jump as the connection seem loose. Short of finding the original connector, I'll do the female bullet connector with a new wire (this one is probably "well done") covered with red shrink. I'll post any finding once I'm done for future search... which I did not do ![]() ![]() ![]() rnln, did you go back to work?
If your cab is an 83 the sender is Carrera not SC. The SC is just a clip on spade.
Bruce |
His 83 cab has a 3.2 stuffed in it! It's a really nice car!
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
