rotated instruments
Hi. What's up with some 911s being sold here which have rotated speedos, and some speedos and rpm meters? Does it mean they have been tracked and that's an easy way to watch the needels (horiz or vertical)...? Thanks.
Old 11-05-2010, 04:34 PM
Poor-sche Lover's Avatar
Yes, some guys do it so that it's easier to see redline as vertical for racing purposes. In my case, the speedo is rotated so that I can actually see the important numbers over my after-market steering wheel.
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 11-05-2010, 04:51 PM
With some steering wheels that are smaller diameter, you can't easily see the 60-90 mph range, so some rotate the speedo to the left.
Old 11-05-2010, 05:14 PM
VFR750's Avatar
Rotated the gauges for the exact same reasons.
I like 6000 rpm at TDC, and redline just a little over. It takes less of a eye drop to see (perceive ) it. It is just my preference. Some things take a little getting used to: Down blinker to go left, up blinker to go right.
Smaller aftermarket steering wheels block the 60-90 range. Rotating the gauge makes it easier to keep an eye on it.
Also, I rotated the oil gauge counter-clockwise for the same reason. Steering wheel blocked the oil temp.
Was the car tracked because the gauges were rotated? Ask the owner. Cars can be tracked regardless of the gauges.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 11-06-2010, 07:25 AM
winter
Winter's Avatar
Excuse me if you already know this, but you can easily rotate the gauges back, they're "pressure" fit into the dash with a rubber ring. So don't worry about that.
Tom
'76 Targa
Old 11-06-2010, 07:40 AM
agrimmitt's Avatar
Location: Mesa Oaks, CA: Zone 8>PCASB/PCACC/POC/NASA member
Send a message via Skype™ to agrimmitt
Thumbs up Rotation view
I like many others have done it for the same above reason as "Poor-sche Lover". I have made the change going back to the '70s on most if not all my Porsche. And now wouldn't have it stock, because I feel I have a better view of what is happening. I enclosed a current shot of my dash package. Easy to do, and easy to change back if you don't like it or sell the car.
Go for it!
art
agrimmitt@pelican
Old 11-06-2010, 08:56 AM
