Targa Bar Seal
OK Targa owners, more questions as I try to unravel the mystery of the Targa top and how it seals. I believe the seal in the photo is referred to as the Targa bar seal. I also understand the area where the window meets the seal is designed to be covered with cloth to allow the window to slide freely. If so, mine looks pretty thin? The rest of my seal looks OK. How much difference will I see in the cloth betwen the new and old. And what is entailed in the replacement? It seems the old seal is glued to the Targa bar? Are there alignment issues that go along with a new seal?
JPL 2004 C4S |
Wash. State
Get yourself a fabric marker, black, and put a coupla coats on it. Just keep marking away until you get it nicely blackened. Every year or so touch it up. Your's looks to be pretty solid still, I would just follow my (proven here) advice!
![]() And I don't believe the cloth is even necessary ; I have seen it removed, and the same marker used to darken the rubber underneath. Either way, no problem with the windows that I've seen. You CAN peel that cloth off and be done with it..... Last edited by nesslar; 11-04-2010 at 05:40 PM.. |
Very helpful, thanks Nesslar.
JPL 2004 C4S |
Member 911 Anonymous
keep the fabric on and darken it.
the exposed rubber will cause the window to go up with some resistance unless you maintain it with some lube. Ask me how I know. Here is a test, with the door ajar raise the window. Observe. Close the door and raise the window, Observe. If you have an old bicycle inner tube place it where the seal would be and raise it, it should bind a bit. Sorry my 2 cents.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Wash. State
Oh no, I agree, no "sorry" necessary; that's why I said his "looks solid"....best left orig. in this case I have to say.
Ok, the existing cloth looked very thin to me with a few areas where it was actually worn thru. I was just wondering if the cloth on a new seal would be much thicker or if it was worth changing now. I was planning on changing the lower door seal which is in poor shape and thought I might change both at the same time. Sounds like living with it is the best plan. Thanks again.
JPL 2004 C4S |
Senior Member
The Kiwi shoe polish applicators with the squeeze bottle and foam mesh ends work very well in this situation - get the Bishop black socks color (joke!). Squeeze it on liberally.
'78 Targa in Minerva Blue |
Wash. State
That sounds like a great way to go!
I used fabric paint per the tech article in Pelican.
I used black with some white added, could not find any gray mixes mentioned in the article at my local craft store. A huge change when combined with painting the faded Targa bar. My wife says it looks like a different car now. Before ![]() Before Detail ![]() After ![]() After other side ![]() They want almost $300 for that piece of rubber....................I'm too cheap for that.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 11-05-2010 at 08:48 PM.. |
Kach,
Wow, the difference is impressive. Aside from the aesthetics, I was also concerned about the windows sliding up and down absent the cloth. I believe I had read a thread here some time ago indicating without the cloth, the window motor would burn out due to friction between glass and rubber. I saw Draco mentioned some lube to avoid that but not sure what lube would work, particularly one that wouldn't transfer to either the window or your clothes as you get in and out. Thanks to everyone for all the suggestions.
JPL 2004 C4S |
