Banned but not out, yet..
RSBob's Avatar
In a completely different direction - look under your dash and make sure all the plug connectors are in place and snug.
A year ago I hit a big pot hole and everything stopped immediately. Since I was on a major highway at rush hour, I had it flatbedded to a local shop where the owner said - I can fix this in 15 secs. He ran his hand under the dash, found the loose connection, popped it back in and the car fired right up.
Old 11-06-2010, 09:01 PM
Thanks guys
Right now I have electric to everything and I can hear the pump running but I am getting zero fuel out of the accumulator. Not even a drop. If the pump was obstructed I should be getting a little gas out of it
1982 SC
Old 11-06-2010, 10:59 PM
Senior Advisor
James Brown's Avatar
the pump can fail (not pumping) anytime. At this point, remove the pump and bench check it or just replace it. I know they should last forever but, well, it's a mechanical part, subject to failing at any time.
08 Cayenne Turbo
Old 11-06-2010, 11:02 PM
Crack the incoming line and make sure fuel is getting to the pump now.
Old 11-07-2010, 06:17 AM
muck-raker
kidrock's Avatar
FWIW, I once jumpered my DME to find out if my pump was causing a "no-start" issue. Once jumpered, I could clearly hear the pump "running", but was not getting fuel to the throttle body.
I went ahead and replaced the pump anyways, which solved the problem.
Just because you can hear the pump motor whirr, doesn't necessarily mean that the pump is doing it's job.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 11-07-2010, 09:14 AM
I will check the line to the pump when I pull the pump Monday. It says it is has a 24 month warranty and it is well under that. I bought it at Pelican but I have never had to warranty anything with them before.
1982 SC
Old 11-07-2010, 10:21 AM
It was a failure of the fuel pump.
I had just installed a new Bosch fuel pump 8 months ago and it failed without warning.
I couldn't believe that it would be the pump but after I eliminated everything else it was the new pump.
Pelican says it is warranting the pump.
What a pain in the a$$
Thanks for the input
1982 SC
Old 11-11-2010, 12:36 PM
Fleabit peanut monkey
Bob Kontak's Avatar
When you lift the air sensor, does it make a screeching sound from hell?
Check this video about 10 seconds in.
YouTube - Comprobando pulverizacion , goteo y caudal inyectores mecanicos K-jetronic
Old 11-11-2010, 04:13 PM
muck-raker
kidrock's Avatar
That's actually good news, Steve. Pretty simple fix, but I realize it's a pain in the azz to replace something that should be rock steady when new. Life happens.
STONE
Old 11-11-2010, 04:45 PM
