Greasing up polybronze bearings
My set of polybronze bearings for my a-arms are squeeking (at least that is what I think is squeeking). I installed about 8k ago and drove through the winter and snow. Squeek just started and is way annoying.
I have a manual grease gun but not sure if it will work (do I need one for air compressor) or if I need a tip different that what I have. The grease fitting on the bearing looks rather small. Thanks in advance. Chris
Chris 1985 Carrera http://www.pelicanparts.com/gallery/ckmaggie |
I installed mine about two months ago and use a regular grease gun. I did have a new fitting but it worked fine. The other thing you can do is pull off your a-arm and re-grease manually.
Most nipples on zerks are compatible with the generic gun. Sometimes the overall diameter of the zerk will throw you. You are only concerned with the business end. You will know if you place the gun squarely on the zerk and grease goes in and not out from the sides of the nozzle. Even then, wiggling around, repositioning and resealing the connection might still do the trick.
Do you know what kind of grease you intend to use? I think many formulations are acceptable, but after talking to Chuck at Elephant, I decided to use Neo synthetic. Valvoline 986 Synpower that Early_S_Man stalwartly recommends should be plenty good, as well. |
I just installed mine, used a cheapo grease gun from the local farm/hardware/housewares store. Worked great.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Though there other styles of grease fittings, all the ones with the bulbous nipple head (the familiar style) use the same tip.
Chuck Moreland - elephantracing.com - vonnen.com |
Just tried again and seems like grease is just squirting out the sides. how do I know if any is getting in?
I pushed on the little balls inside the fittings to make sure they were not frozen and they don't appear to be. I can't get to the rear fitting until I jack up the car, which I will do tomorrow. I guess I'll know it works if the squeek stops. Chris
HOLD the nozzle with your hand. Keep it straight on the fitting. Don't let it get angled while pumping the grease. You can do it!
David Duffield (Was a High School Cities Service employee) |
Me like track days
A local shop noted that "grease squeezed out the sides with not much getting around the bearing". They are checking on wear patterns as time goes on (disassembly and inspection). I have nothing to do with this process, btw.
So FWIW, I pre-greased the whole shebang before installation and regreased once installed.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I regrease mine at every oil change (which means annually, more or less). No squeaking. Push grease gun tip onto the zerk, pump until grease squeezes out the sides of the bearing. Then wipe off the excess.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Guest
Posts: n/a
Is there a reservoir for the grease, or do you does it just surface coat the contact surfaces?
Friend of Warren
Mark there are two grooves cut in the bronze bushing so some grease resides there. As the arm moves up and down the grease migrates to the rest of the bushing.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Information Junky
Re: Greasing up polybronze bearings
Those little hood-adjuster-bumper may be out of adjustment, allowing the hood to move (and squeak) more than it should. (this happened on mine once) . . .or maybe a swaybar bushing?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
I'm using a standard fitting with a flexible hose. Thanks.
SC |
Make sure the tip is snapped onto the fitting, nice and square.
Thanks for the reply. I'll try that. Here's what I'm using, if that changes anything.
SC |
make sure the tip outer diameter is not hitting the spring plate cover.
You may need to grind/file a flat on the side of the tip to relieve interference and allow proper seating on the nipple.
If you drove the car through the winter, might just want to pull the cover plates off and clean the winter grit off the polybronze parts. Then coat with fresh grease and reassemble. If you have to drive the car through the winter again you might want to hit with a grease gun monthly.
FWIW the ER Polybronze have been in my car front and rear for 2 track seasons- probably 30 track days. I hit with a hand held grease gun every other event and have never made any noise
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Thanks, I'll get to that at some point. Don't think our winter's are as harsh as yours.
So I got the tip snapped on to the fitting - that was apparently what I was doing wrong. I guess once grease starts squirting out (i.e. not going into the bearing anymore), it's pretty much full, right?
SC |
