Sorry for another no start question...
Trying to help a friend solve a no start issue with a '74 with an '84 Carrera motor. The motor was rebuilt with only about 15k on it. The car had been sitting for a long time with only occasional use. Anyway, the story is the car had been running fine until it all of a sudden would not start in a parking lot. Actually it started but died two seconds later. Towed it back home and have since replaced the DME relay, plugs, reference sensor, and confirmed the computer is working with another friend's car. The fuel pump seems to be fine. Battery is a year old and fully charged. It looks like we don't have spark and electricity to the coil. Took the spark out and tested it against ground with no spark. Also put the positive end of a voltmeter to the coil and ground with no electricity. No clicks from the DME relay when in the "on" position. The ground wires to the left of the intake look good. The car cranks fine-just no spark. Are there other grounds or other things we should look for? Thanks in advance.
Old 11-06-2010, 07:25 PM
RETIRED
Joe Bob's Avatar
You need to start testing the harness for constant 12v, 12v with ignition on and a few other issues. The "PET" has a trouble shooting section and is downloadable on the net.
There are very recent threads on this, including my own with my 3.6 which has a similar DME.
PM me if you'd like and I can send you my telephone #.
2012 ML350 3.0 Turbo Diesel
Old 11-06-2010, 08:13 PM
RETIRED
Joe Bob's Avatar
BTW, I just checked.....I have the Carrera TS manual. If you have a decent server and take big files I can email it to ya.
Old 11-06-2010, 08:14 PM
