Your trying to match engine RPM to trans. RPM. When you let the clutch out after placing the trans in neutral (up shift= no blip)your allowing the trans. to slow down to match the engine RPM. Likewise on a downshift you need to raise the RPM (blip) to match the lower gears RPM |
The thing is, some will 'rebuild' with only new syncro's but re-use the sliders (which are likely worn) or re-use the worn dog-teeth. A well sorted 915 is fast to shift. |
Not to boast or say anyone is wrong but, all three of my cars shift into second up and down with no problems. I use kendall and all the linkages are tight and adjusted properly. The adjustments are the key and they are finicky.
BUt mileage may vary.... I guess if you shift fast enough a blip is not needed but my 2.7 as previously stated spins down too quick. |
Royal Purple, I've heard good things about. Kendall, too. Better than Swepco. |
In reading about SW chips, I'm under the impression that the new mapping reduces the quick drop in engine revs.
Would this aid in shifting? I don't have a SW chip in my car. Just based on what I've seem here. |
I run SWEPCO.....happy with it....
I find all upshifts go a little easier if I do not lift completely off the gas while shifting such that the revs stay a little elevated. 1-2 has always been fine for me. 3-4 on the other hand can be a little difficult but my 915 is not the awful beast that some seem to be burdened with.
1.) regarding double-clutching upshift....all sequence shown is correct *except* don't blip throttle.....you are not rev matching going up...only down.
2.) What?....Swepco 201 , a non synthetic....has been the "de-facto" recommended lube "precisely" for the baulk-ring type synchromesh that the 915 box has. You're getting this goofed up with G50 trans, with it's Borg-Warner style (cone?) synchros....which DOES cater to synthetics. Make sure it's GL-5 rated. Oops....didn't read all the subsequent responses...answers already noted. |
If you really have problems shifting, and it is not the box or the linkage, consider that your clutch or pilot bearing may be dragging.
Swepco, new shift ball bushing and coupler bushings...........and most importantly a Seine System shifter spring thing a ma jig.
PEL-SEINESHFT Seine Systems Gate Shift Kit, 911 (1973-86) Porsche 911 & Carrera Shift Linkage - Page 2 http://www.pelicanparts.com/catalog/...ateshifter.jpg The best $150 you will ever spend. |
Thanks to everyone for the replies to my double-clutching upshift question. When my 911 is back together I will try that without a throttle blip on the upshift.
A good rebuilder like John Walker will know how to source replacement parts (and even to sometimes correct the currently-being-produced ones that are sometimes not to spec as they come off the shelf). And a 915 shifts just fine when it's in spec. Mine has been running Swepco forever and it shifts great. I don't need to 'think about' shifting at all -- much less double-declutch or count out numbers in my head or play with the throttle. |
If you are pausing in neutral with the clutch in you are wearing it out.. if the clutch is out then you are not. |
Swepco?
Can someone please give me concrete data on Swepco vs. Kendall. I have 2 Porsche mechanics & they are on opposite sides of the fence on this. My 915 seems to get harder to shift into 2nd as it gets hotter. I was told the thickness of Swepco would help w/ this but I have read on this site that it may shorten tranny life. My 911 is @ Eurowerks in Charlotte as we speak. If you guys can make a case for Kendall I am gonna have them change it while it is there.
Also, don't forget, if you upshift (of course) AND downshift, you are putting double the use on the clutch / trans. I usually let my brakes take the beating as I am slowing down, as they are much cheaper to replace. I only downshift when I am in speed-racer mode. :) Doug |
915 shifting threads are always interesting to read, most guys experiment with technique and some want to improve it through component changes and adjustments. Some guys seem to be so comfortable with their 915, I think they must not notice the subtle things they do versus jumping into the wife's new Jetta. I've driven a number of examples of this tranny (a few having been recently rebuilt), and although there is definitely smoother action and faster shifts on some of these cars, I've never driven one yet that shifts close to modern standards. By that, I mean, Joe average jumping in a car and making it go smoothly with no instruction or experience. Guys with lots of experience with this tranny can shift pretty quick and smoothly.... but it requires time in the saddle. I personally find the fastest way between first and second is modifying engine speed and not allowing it drop off completely (as was said earlier), not a "blip"...... but a maybe you could call it "an extended quarter blip". Cheers
| All times are GMT -8. The time now is 08:17 PM. |
