Third Brake Light - Where to Mount?
I have a 1985 Targa, and have found some great information here regarding installation of a third brake light as well as the many styles available.
So far, I think I like the more traditional/standard block that would sit against the interior rear window of the targa. (Daniel Stern sells Hellas that use LEDs. They look nice.) Where should I mount the light? Up high behind the targa bar or down low on the rear deck? ![]() Having only original brake lights is a scary proposition when I have an SUV bearing down on me--I'm sure they don't see them! Thanks. Lawrence |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
On the '86, the light was mounted under the Targa bar. For the '87, the light was moved to the bottom of the window, perhaps for better visibility. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 11-18-2010 at 11:27 AM.. |
If it were me, I'd put it at the top to be seen better by high-riding SUVs.
Larry Red car w/black tires |
installed mine high/targa bar..
I don't see..they do Rika |
Jupiter 911
On my 87 Targa I mounted on the rear deck.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
Visibility for inattentive texters would be better if it's higher, I'm thinking.
I've picked up a used Porsche unit that I'll wire in inside against the targa bar. |
Mine's a coupe but here's how I did mine a couple of weeks ago.(plus other Pelicans)
How to: 3rd brake light install
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Swoboda:
First mod I did to my 82SC was the Stern LED. I mounted it on the rear shelf. Looks original, especially with the Hella lettering. I can take a shot of how it looks tomorrow if I remember.
G. Hamilton '82 SC Guards Red-2nd time owned-Now sold "Bumerang" '70 TR6 N of Boston |
The PO mounted a factory piece in my previous 85 coupe. Up high. "Completely" obscures my rear-view of my interior rear-view mirror. If it was mounted down low....then YOU can see out...but THEY behind you won't see you as well. You are better served with a high-mount from a rear-end collision avoidance standpoint.
Compromise?.....mount high.... but use a very thin strip of a row of LED's and dtich the factory "brick" light.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Senior Member
The superthin spoiler insert red LED light bars are ideal for tucking up under the Targa roll bar.
See at eBay - click
'78 Targa in Minerva Blue |
Should there be any concerns about brightness or DOT approval?
Lots of posts about LED strips don't reference that, although they all do seem bright--and anything is certainly better than nothing when it comes to a 3rd brake light. |
Detached Member
I did what Oh HaHa (Wayne) did and you cannot see it in your rear view mirror. If angled correctly its very noticeable to those behind you. I ended up using a black two-part epoxy to attach it to the inside of the glass.
Hugh |
AutoBahned
there is an accelerometer based gizmo also - no wires
Member 911 Anonymous
On my Targa, I placed at the bottom for much better visibility.
I used the strip type to give it a little update look. We are 85 so we are DOT exempt for a third light in any case.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
