tight as a bull's ass's Avatar
OOPS....I did it again! Alternator connections!
well, finally got back to working on this alternator this week and what's left to do is wire up the connections...unfortunately, I didn't write them down before I took the wires off....
Terminals E and F I have figured out......but there are 2 wires left that must go on either A, B, C, or D.
Before I make the wrong connections and fry something, does anyone know how to rewire this thing?
The car is 1970 911T
Thanks a lot for your help!
www.swirlednews.com/article.asp?artID=501
The data in the CD-type disc decodes easily into ASCII computer text as follows, using 8 bit binary:
"Beware the bearers of FALSE gifts & their BROKEN PROMISES. Much PAIN but still time. (Damaged Word). There is GOOD out there. We OPpose DECEPTION. Conduit CLOSING (BELL SOUND)”
The damaged word would appear to be intended as “BELIEVE”.
Old 03-05-2002, 03:25 PM
304065's Avatar
Porsche Crest Alt Connections
You should have four wires:
DF (black) or "Dynamo Field" goes to tab "F" on brush holder
D+/61 (blue)- "Exciter" circuit from warning light- to "B"
B- (brown) "Ground"- goes to alternator case ground "E" or B- terminal
B+ (large red, or 2 large reds) "Hot" to terminal "C"
Run the wires through the air guide first. Good luck, stand back, watch for smoke with fire extinguisher at the ready (not kidding, I always do this particularly around high-wattage electrical connections)
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-05-2002, 05:27 PM
Super Moderator
cstreit's Avatar
Now as a musician, you should be shot for quoting Brittany Spears...? "Oops I did it again.." For shame!
Sorry emmanuel, couldn't resist...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-05-2002, 09:50 PM
John,
Thanks for the information. I wasn't expecting such a quick response. The fire extinguisher will be close by!
Chris,
LOL, , I'm not particularly a big Britney Spears fan (the singer OR the actress)...
however, "OOPS....I did it again" is a phrase I often mumble to myself when working on the p-car.
Old 03-06-2002, 05:34 AM
