grahamkissack's Avatar
How to fix a broken window regulator spring retainer
I dont see where this came from in the katalog? Thoughts? Thanks!
"Penelope" 1980 SC Targa in Grand Prix White
Old 11-21-2010, 02:57 PM
Thanks ... just found where it came from....now to try to fix it!
Old 11-21-2010, 03:07 PM
So there are a few threads on fixing this broken spring retainer which I heard break while drving earlier this summer.
Found this on my left rear floor mat - any guesses?
Part found inside driver door - What is it?
But I'm not clear on how to get the regulator out to do the repair. Do I lower the glass or keep it up? Bentley says lower it half way then raise it by hand and tape it up....thats a challenge with a Targa door?
Old 11-21-2010, 03:32 PM
steely's Avatar
I'd suggest half-way. The targa has no trailing guide making the window somewhat unstable above the halfway point. maybe use a block of wood too in case the tape gives way
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-21-2010, 04:30 PM
HarryD's Avatar
Hi:
That is a pivot pin. They come in 4 flavors and you will need to look at your to figure out which one you will need.
You will need to remove the door card and regulator to figure out what you need to do.
It is not hard (I have done both of mine).
This article tells you how to remove the door card:
Pelican Technical Article: 911 door panel remove
This article tells you how to remove your window regulator:
Pelican Technical Article: 911 Window Regulator Replacement
Some Threads on Pivot Pins:
Argh!!! Window Regulator Frustration
Window Regulator Pivot Pin
There are lots more as well if you do a search.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-21-2010, 05:47 PM
HarryD's Avatar
Like I said, I have done both of mine. Just tape the window to the door top and the vent window.
Harry
2020 MB E350 4Matic
Old 11-21-2010, 05:48 PM
MBAtarga's Avatar
Funny how many times this same part is found within a door. I already knew from the thread title what it was going to be.
Mark
'83 SC Targa - since 5/5/2001
Old 11-21-2010, 06:58 PM
Ok...got it fixed.
Removing the regulator is like a ball joint ... why was that so hard. I ended up removing the power window motor to get it out...couldn't see any other way.
Here's the replacement bolt (with a low profile flat head and square shaft) that I stalled to hold the spring in place of the failed aluminum piece.
Old 11-21-2010, 08:34 PM
HarryD's Avatar
Interesting. Usually it is the pin in the middle that fails.
Harry
2020 MB E350 4Matic
Old 11-21-2010, 09:22 PM
Now accepting US $ at par
dienstuhr's Avatar
Apologies to Poe
Once upon a midnight dreary, in the garage, weak and weary,
Pond'ring Porsche projects that I should have done before,
Then I spotted, unexpected - suddenly my eyes detected,
A tiny part unwitting, simply sitting in my Targa door.
`'Tis a pivot pin,' I muttered, `sitting in my Targa door -
Only this, and nothing more.'
Glad you got it reassembled
d.
1985 911 Carrera Coupe
2015 Volkswagen GTI 6-spd
some motorcycles
Old 11-22-2010, 12:42 PM
steely's Avatar
yeah, Harry, I think you and talked alittle about this once before -the little white-metal pin is swaged/pressed into the regulator and not available as a separate part - and has a much smaller profile than the center (what I was calling the pivot) pin.
grahamkissack - nice work!
Dan
Venetian Blue
Old 11-22-2010, 01:24 PM
esotoracing's Avatar
So thats where i left it! Dang it !!!
theres nothing like the rear end squatdown of a turbo
Old 11-22-2010, 05:00 PM
