There we go.
I believe what is at work is a lean mix burns slower because there are less fuel than oxygen molecules packed together. Because it is burning slower it makes heat for a longer time inside the head and cylinder. Thus, more heat is retained in the motor. Get to much heat and detonation can occure. With a longer burn time timing dose have to be advanced to achieve peak pressure near the ideal which I think is about 12 to 14 deg atdc. Thus, we have to start building pressure earlier on the piston's way to the power stroke. Not sure but I think this called increasing our 'pumping losses'. This pressure before TDC takes away from the power made by the pressure built up ATDC and thus reduces our HP. Twin plugs do accelerate the burn rate and ensure a poor mix is ignited. Especially important with low compression where the mix is not as closely packed. Thus, should not make for any higher peak cylinder pressure when ideally timed. It dose however reduce the among duration over which pressure starts building on its way to the power stroke. On a Porsche this can make for about a 3% increase in power. I am still learning so take this with a grain of salt. |
wannabee wannabee
I'm sorry... I threw out the wrong number there... I meant .035 inches as opposed to .028 (copper plugs for a 3.2 motor).
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
too much heat and detonation will occur. yes advancing timing to "fix" a lean condition, no. first, the only way to properly set timing is on a dyno, anything other than that is guessing. timing is increased until no more power is made at a given RPM. any further and it reduces HP. once timing is set, you dont change it. second, timing and fuel mixture go hand in hand. if you change one, you have to change the other. look at it this way. lets say your mixture is 14.0 and timing is 15 BTDC. if you increase the timing to 20 BTDC, the fuel has longer to burn. more burn time will give the "appearance" that the mixture has gone leaner. a gas analyzer may now read 14.7. the mixture may look good now, but is the timing set for optimum? not if peak HP was created at 15 BTDC. you have "fixed" your mixture but your HP is down. since most of us dont have dyno's, we have to either rely on what someone else has found out, or go by porsche specs for timing and tune around that. twin plugs are not for low compression poor mix conditions. its for the hi compression engines. you want the combustion process to happen faster, but at a controlled rate. study the article in that link. it has a lot of good info. not sure what your last sentence means.
A post I made back in 2006
what could cause this? Quote:
I also use this spark plug tool, it helps get the gap level but is a bit shoddy. Summit Racing SUM-900313 - Summit Racing® Spark Plug Gapping Pliers - Overview - SummitRacing.com ![]() Our host may sell the same tool or something better, check around. With gaps these small you need all the help you can get.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
i believe permatune recomends a pretty wide gap. i have set mine pretty wide, but i was having other issues at the time. i set mine now between .040-.050.
i have an MSD setup.
Thanks Wil, that is right where I have mine now at 0.035 inches. I feel that 0.040 should not cause a problem and after reading the posts I now do not think it is a good idea to go as Big as I can and end up wearing out the Ignition Wires or carbon lines in the Dist cap.
I like that Plug Gapping tool and think I will get one. Like most of us, if the tool is neat I want it!
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
wannabee wannabee
