Old 60's Porsche Tech
R & r front sway bar 1987 carrera??
Need to remove the sway bar bushings to clean and lube squeaking like a &$#*^. Any tips on doing this? The shop said it is a ***** to do. I may replace the bushings while there out. Let me know the easiest way, Thanks JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
If the sway bar is squeaking then the bushes are shot. New rubber ones are cheap. They could be the hard plastic type which is why they are making noise and the rubber factory bushings work fine. Getting the bar out is easier than reinstalling. There are a number of methods, which you can search on and find the method that works best for your level of skill. To remove, lube the bushings and get your foot on one side of the bar near the a-arm and push.....hard! Reinserting can be as easy as inserting one end of the bar first a little farther than necessary and then, with massive biceps, pull the other end into the bushing without pushing the bushing out of the a arm (BTDT). Or you can lower one a-arm, insert the bar and reattach the a arm.
Do yourself a favor and search the threads for tips, pictures and other methods.
Tony G 2000 Boxster S |
