Virginia Rocks!
VaSteve's Avatar
Running SC + Dwell Meter...anyone?
I bought a dwell meter this morning to test the ongoing issues with my CIS car. I wanted to see what kind of results I got. I don't understand these results...and/or I hooked it up wrong.
First photo is while the car is warming up from sitting all night. Second photo is after I took it for a short drive to warm it up....barely get a register. The Bosch book says to compute against the 4 cylinder scale, this one doesn't have one. Can I use the 6 cyl scale? I can't interpret this...can you?
Also, does anyone have a well running 81-83 SC who could hook up your dwell meter and get a similar photo? I don't know what the heck I'm looking for out of this....I expected the numbers to be higher.
Even weirder, I found that when I disconnected the lead on the test port with a warm engine, I heard a distinct buzzing sound start. It was not buzzing while lead was connected.
In the second photo, if I started the car, the needle would initially go up as high as the first photo for a couple of seconds and drop back as you see it.
Uploaded with ImageShack.us
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 11-26-2010, 10:55 AM
Your car has to be warmed up for you to meaningfully read the test port results. As it says on the face of your meter, double the eight-cylinder scale for four-cylinder values.
Ultimately, you want your mixture set so the frequency valve duty cycle is at ~50 percent, which would be 22.5 degrees on the eight-cylinder scale.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 11-26-2010, 11:26 AM
Sounds like the meter or your hookup is grounding the circuit. Does the meter have a +12v and ground connection ?
Paul
Old 11-26-2010, 12:59 PM
Virginia Rocks!
VaSteve's Avatar
Brian
OK I was overthinking it since it's a 6 cylinder car.
Has two wires, green and black. Green went to the green/white pin in the port, black to ground. Which based on your comments sounds like I was in error. Neither the instructions, the Bentley or the Bosch guide say exactly what to hook it up to.
Old 11-26-2010, 02:23 PM
An engine's actual cylinder total doesn't matter in this case. The engineers back in the day decided that the common convention for lambda language would be four cylinders, thus the use of the four-cylinder duty cycle scale. Or something like that.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 11-26-2010, 02:55 PM
grateful user
don gilbert's Avatar
make sure your 02 relay under the pass. seat is working.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 11-26-2010, 03:15 PM
Virginia Rocks!
VaSteve's Avatar
That is what I was trying to test. If the relay was working, the FV would work and indicate *something* on the meter, correct? Do I have the meter hooked up correctly? The actual O2 sensor is disconnected from the circuit.
Old 11-26-2010, 03:30 PM
Green 912's Avatar
I have a digital O scope if you want to see the duty cycle and wave form. The shop is open Sat a.m.
Old 11-26-2010, 03:44 PM
Virginia Rocks!
VaSteve's Avatar
I saw that, thanks!....I'll bring my garage monkey if yours will be there. No swimming this time.
Old 11-26-2010, 03:56 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
well, just to be clear, where/how do you have the meter hooked up?
Old 11-26-2010, 06:45 PM
Virginia Rocks!
VaSteve's Avatar
Green from the meter to green/white in the test plug. Black to ground.
Old 11-26-2010, 07:18 PM
Green 912's Avatar
My shop monkeys will be around. Koi ponds are covered for the winter.
Old 11-26-2010, 08:20 PM
arbita1's Avatar
You know...I have the same exact meter and I've been having the same exact problem as you. I thought it was the O2 system not functioning correctly...but now I'm wondering if this type of meter will not work for this application. I even get the frequency valve to stop buzzing like you.
Here is my thread...
Help Troubleshooting O2 Sensor System
I wonder if anyone else who has this brand of meter has gotten it to work correctly.
Matt.
83 911SC
85.5 944 NA - Sold
Old 11-27-2010, 07:52 AM
My Question is how can I adjust the Duty Cycle?? I would like to have a reostat on my dash "Power / Fuel Mileage!"
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 11-27-2010, 12:21 PM
I have the same dwell meter and it works as it should; works as described in the Bentley.
The duty cycle adjusts according to the mixture. I have taken note from Don_Gilbert and am plumbing an adjustable full pressure regulator into the cabin. The reg. takes the place of the WUR (control pressure reg) and allows me to change the pressure at will. Thus allowing me to twist a knob for mileage or power.
I am also making some plans to modify the WUR and attach a cable and lever. That way I could adjust pressure without plumbing fuel into the cabin.
Old 11-28-2010, 01:29 AM
grateful user
that is the 02 sensors job. You can adjust freq. of dwell by moving your 3mm allen screw to get it with spec. If the 02 relay is working, you can feel the freq. valve vibrating. Your freq. valve (just an inline injector that bleeds press. off in the lower chambers of your fuel dist.) also is what richens your mix when you go past the 35 degeee throttle switch. with it inop, you could be in a lean situation at wot. (not good)
Old 11-30-2010, 05:26 AM
grateful user
my control press regulator, can adjust afr on the fly intantly.
Old 11-30-2010, 05:44 AM
Virginia Rocks!
VaSteve's Avatar
Anyone have any additional data points on this? We were unable to get a reading with the digital oscilloscope.
Old 12-11-2010, 01:00 PM
