a.k.a. G-man
Geronimo '74's Avatar
RSR engine support Q and pic
Did the RSR (964 or 993) models have this type of engine bracket?? It's aluminum.
It's listed for 350 € , kinda steep, no?
Anyone have a partnumber??
Old 11-29-2010, 12:19 AM
slodave's Avatar
Rennline offers a similar one, advertised as an RSR style bracket. I have one.
Old 11-29-2010, 12:35 AM
petevb's Avatar
Who makes the bracket at the top? Looks very different in detail to Rennline (or original)- aluminum vs stainless, and I can't see horizontal flanges/ upper and lower lips in the piece at the top? Instead it looks like a thicker flat plate? If so I think it's a questionable design- those lips were key for strength to weight ratio. Any other pics?
That a 911 RSR style carrier, not 964 or 993. The original porsche part did have similar holes, but I believe it was steel and had a lip welded at the top and bottom...
Old 11-29-2010, 01:01 AM
slodave's Avatar
Earlier version of the Rennline...
Old 11-29-2010, 01:13 AM
a.k.a. G-man
What I thought, I guess it's a knock off, not worth the money....
This is the only pic.
Old 11-29-2010, 01:32 AM
jury's Avatar
Send a message via Skype™ to jury
I got mine form here in the UK:
Welcome to R-TO-RSR.com
In the parts section, under engine...
Also try:
Canford Classics - Classic Porsche Restoration & Parts Refurbishment
Chris
Old 11-29-2010, 01:47 AM
a.k.a. G-man
Also try:
Chris
Thanks, great stuff on the first one and closeby too!
Old 11-29-2010, 02:07 AM
If it is aluminium it will need to be about 3 times the thickness to have the same stiffness as a steel part, which means it is about the same weight.
Ity is also likely to have a relatively poor fatigue resistance and could well crack in a relatively short timescale.
We are just making a batch of RSR Engine bars from an extra high strength steel.
(http://www.ssab.com/Global/DOMEX/Datasheets/en/421_Domex%20700%20MC.pdf)
We have chosen Domex S700MC as it is ductile, weldable and extremely strong but doesn't have any weight penalty on a conventional steel. It will have great resistance to cracking and permanent deformation.
They will be ready in about 10 days.
Old 11-29-2010, 02:24 AM
