Super Moderator
Two brake options, need help choosing!
Okay gang, I have the racecar brakes down to two options but could use some noodling around which one to choose... Any pros/cons you could provide would be happily received!
86 944T calipers front and rear. - For those technically inclined, front 2x38 2x38 pistons, rear 2x30 2x28 pistons (1.61 bias) - Use Adapters to fit calipers from vendor (like VCI) - 292x28 944T/964 rotors on front - 298x24 944T/964 rotors on rear - 23mm master - Cost about $2000 96 993 calipers front and rear. - S4's and litle reds (2x44 2x36) and (2x30 2x34) - Adapters to fit - 309x28 930 turbo rear rotors - Custom rotors and hats from VCI or rennsport front - 23mm master - Cost, about $2000 (because I have these calipers already) THe thoughts I have... Pro 993: Well the 993 setup is obviously bigger and fatter discs Pro 944T - 993 setup won't work under 15's - 993 setup requires custom disc's/hats, cost $360/pair whereas the 944T cost $160 What do YOU think?
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 01-26-2002 at 08:30 AM.. |
Senior Member
That's not much of a difference in costs. the non-water cooled brakes are bigger, and they are also designed for a weight bias more like your car. Don't use 15" wheels.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
What's wrong with 930 brakes? :-/
Thank you for your time, |
Super Moderator
The 930 brakes are great... But TWICE the cost...
