Irrationally exuberant
Fuel injection, rev limiting methods
Here's a question for you gurus:
Besides cutting fuel, what methods are employed to limit revs in fuel injection systems? I've heard that just cutting the fuel can lead to leaning out the mixture with bad consequences. Pointers to sources of information on this topic would be appreciated. I'm in the very early stages of "hacking" the code in the Motronic DME in my '86 Carrera. thanks, Chris Keywords: Motronic, DME, 8051, EFI |
I believe that most modern forms of rev limiting work by cutting spark, not fuel. On my twin-plug MSD setup, for example, one set of plugs cuts out at 7,300 rpm and the second set at 7,500, giving a relatively soft limit.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Thanks Stephan. Cutting one plug of a twin plug would seem to have it's own problems i.e. detonation. MSD must know what they are doing though.
-Chris |
Senior Member
I consider the no-spark method to be the older of the two (early 911s, before fuel injection used to use rev limiting distributor rotors). I don't care for the idea of pouring fuel into cylinders and then not lighting it on fire.
Cutting fuel in a FI car results in a spark but no fuel to ignite. I like this idea better. Cutting fuel pressure in a FI car causes the engine to quit making power just as quickly as the no-spark solution. It is IMMEDIATE.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
OK contestants, you all proceed to Round Two.
Here are some ideas for comment: - If we cut the spark we get an immediate halt to combustion and unburned fuel goes out the tailpipe. Is this bad for cat?. - If we cut the fuel, gas still intake tract gets sucked in and lit off. Can the temporary lean mixture cause detonation? - Wouldn't "hard" limiters like these be hard on the engine and possibly upset traction/chassis if you're in a corner when it happens. - How's a "soft" rev limiter work? TIA, Chris |
The ignition rotor on my 2.7 has a centrifical rev limiter built in.
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Acording to the bosch fi manual for the DME, they cut back the pulse times to the injetors to conrol the rev limit. This book explians how the dme funntions.
Darren |
You you be more specific on the book you're talking about? It sounds like something I'd be interested in getting. All I have are the factory Porsche manuals and the Probst (sp?) book. thanks, Chris |
Chris, thr name of thr book is called, Bosch fuel injection and engine mangment by Charles O Probst,SAE, I bought it from amazon.com for $19.95 i think, also I think wayne has it too.
Also there is a software program that runs off a pc to a eprom programer that I found on the net, that was made to program dme chips. I have it somewere, I will look for it. Darren |
Hi Chris
This might not help but on the CIS cars when the rev-limit is reached the power to the fuel pump is cut. The motor dies imidiatly (sp) if not sooner. It does not run on the fumes. Dean |
Thanks, I have that book. I guess I need to read it again! I know of two DME editing tools out there.
Bonneville Motor Works has one that they advertise on their web site (unchanged since 1998 I think) but they didn't return my email or calls (a few years ago) so I don't think they are interested in selling it to Do-It-Yourselfers anymore. Promotive has one also - for $1000. Do you think it was one of these? Chris |
Chris, the program I found was the Bonevelle motor works . Is there a site for the promotive software?
Darren |
Darren,
Here is the link for Protomotive: http://www.net-quest.com/~knighton/index.html and their software: http://www.net-quest.com/~knighton/software.htm In the interest of completeness (as my professors used to say) here is the link for Bonneville Motor Werks: http://www.bonnevillemotorwerks.com/index.html and their software: http://www.bonnevillemotorwerks.com/dmeedit.html The Protomotive one is DOS based and the Bonneville one is Windows based. Chris |
I agree that there are two ways; Cutting the spark and cutting the fuel. My understanding is that the preferred method nowadays is to (briefly) cut the spark. This is what was originally done for F1's traction control.
1) Cutting fuel results in a lean mixture and the absolute cut-off of the motor. Picture yourself making the big pass on a straight, holding the gear for max rev's ... and someone turns the motor off. The scenario gets even worse if you are in some sort of a corner. Nothing will happen until the engine rev's drop to the preset restart level. This in turn depends on how fast the car is coasting, if the clutch has been pushed in, the flywheel, etc. It also makes for a very bumpy ride as the motor kicks off and on again. I know because the Mazda I used to race had a fuel cut-off on the rev limiter.2) Cutting spark is usually done on an intermittent basis, generally by randomly dropping sparks to different cylinders. (As opposed to dropping the spark to one plug in a twin plug head. I can only imagine this being a bad thing) The result feels like a car where the valves are floating, the engine starts to sound rough and basically stops pulling hard. Not a lot of fuel is pumped out the exhaust since the next time around that cylinder will fire and burn off a lot of the unburnt fuel. No one is talking much about the newer systems in F1, but they don't make the engines sound anywhere near as rough as in years past. Given "Fly by wire", they may be playing around with throttle, intake trumpets, ignition timing, etc to basically limit the engine's HP at the rev. limit.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Thanks John. Excellent info!
-Chris |
Senior Member
Ok now I am confused. I had to rebuild my 78 sc due to an over rev. This was NOT a mechanical over rev. Long story short is a buried the tach needle for a moment and bent 6 valves and damaged a cylinder.
When I pulled the distributor cap I saw my rotor had a rev limter which I assumed had failed. I planned on buying a new rotor so I would have a functioning rev limiter. Someone mentioned that cis car cut the power to the fuel pump. Mine apparently didn't know this and continue to let me rev away. Where is the device located that cuts the power to the pump and how would I go about t/s the problem. How exactly does the rev limiter work in a 911sc The car is a euro if it maters
78 Euro 911sc Targa 03 Hayden SCWDP |
Crotchety Old Bastard
There is no CIS cutoff on an SC.
There IS a fuel pump cutoff for a CIS 930. The SC uses the distributor to limit revs.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
A few comments about igniton rev limiters. I have found that most igniton limters that drop out the igniton, in time end beating the hell out of the rod bearings. The unloading and loading on the rods beat the bearings. Cuting off the fuel seems to be a better way. Everyone taks about running lean, but when you cut the fuel off,there is no fuel, just spark, you can't burn gas that is not in the chamber.
Darren Last edited by DRD; 01-25-2002 at 11:46 AM.. |
There are two distinctly different methods used on various SC engines, i.e. rev-limiter rotor, and fuel pump cut-off relay, and the spec books give all the specific details.
Soft rev-limiters of the electronic type cut spark to cykinders in stages, first step ... down two cylinders, second step ... down2 more cylinders, etc. The only logical method of doing it with a DME system for the 911 would be to cut spark in three stages, always selecting opposing cylinders 1 & 4, 2 & 5, and 3 & 6 to preserve the smoothest running characteristics. If you wanted to make use of the injectors to cut fuel, it would be best to cut-off the injector bank one after stage two of the ignition cut ... when four cylinders aren't getting spark. The 911 Bosch Motronic system fires the injectors in two banks simultaneously, so you really don't have much option ... all or three injectors. Rewiring the injector banks would optimize control and smoothness, if, for example, injectors 1, 4, & 5 were grouped, and 2, 3, & 6, likewise, you could cut injectors 1, 4, & 5 for fuel emmisions purposes simultaneously with stage two spark cuts, leaving only two running cylinders, but one injector output for cyl. #2 would be unburnt.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Darren; I'm confused -- how will shutting off the fuel not beat on the bearings as much as shutting off the spark???
I'd think the result will be the same. If you ask me, if you are spending that much time on the rev limiter, you're doing something very wrong or you need different gears.osidak, I admit that I don't know the details, but it sounds like the damage that you did was the result of an over-rev from either a missed shift of a botched downshift. Rev limiters won't help a motor with that situation. It's also not clear how often you had been using the rev limiter. I've heard that SC's don't like to be rev'd but I can't imagine that the motor wouldn't survive running at the redline or 500 over. I'm sure that Porsche margined themselves when they built the motor. It sounds like an interesting situation. but I don't understand why you feel that the rev limiter did you in?
