I'm curious about the rear caliper and rotor in this kit, did you post any pics?
Yup - lots of pics here....
http://forums.pelicanparts.com/porsche-911-technical-forum/534247-carrera-suspension-update.html |
No pics of the back side of the calipers
This kit is different, all the GT kits I've seen use the big 993tt/RS rear caliper on a modified 993tt/RS rear rotor, You appear to have the 322x28mm modified rotor(which is supposed to be NLA) but w/ a smaller A family Brembo caliper very curious:confused: |
Bill - I'll try to shoot some pics of the backside of the caliper - It's a GTP Kit that I got here from Pelican some time back.
Bill,
I suspect the rear caliper is a Lotus TwinTurbo V8 application? That's what Jeff Alton mentioned is his ad for the kit he's offering. http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/572341-brembo-gtp-brake-kit.html That car is so clean even a clean freak like me is shocked. I guess getting married and having kids has broken me of that clean fetish, because my stuff isn't even clean anymore! :D I'll see what I can do about getting a picture of my rear line on the 930 caliper. I have to do something about my garage disaster anyway....... |
Kevin - well you just need to marry someone that is neater than you - that is what I did. :cool: I got 3 kids of my own 3,4 and 9 months - but us neat freaks (my wife and I) give them a run for their money...the house stays pretty tidy
My rears look different than the ones in that kit - now Bill has me curious too...I think overall the kit is good, (install wise) I have to install the 23mm M/C and we will see where we are with bias - my guess is pretty heavy on the front but until I get it out on the track for a good shake down I will not know. Appreciate the help on the pics - it would be great to by a rear 930 line and call it day. In the pics you can see where the in/out line goes - it's pretty far down. Bill here are some more pics: http://forums.pelicanparts.com/uploa...1292281060.jpg http://forums.pelicanparts.com/uploa...1292281116.jpg http://forums.pelicanparts.com/uploa...1292281151.jpg |
My wife is neater than me (never stops telling me to hang up my clothes after work, straighten up your pile of magazines, etc. etc...... :D )
Yes your calipers are tapped differently than those in Jeff's kit and they don't have crossover tubes. These are similar to the old Ate calipers with internal plumbing. But I still think the 930 line could be the ticket. Stay tuned...... |
What are the part numbers on that caliper? The Lotus TT one is available with different piston sizes and port set ups. Although I have never seen them with a single bleed screw and a lack of cross over tubes...
Cheers |
http://forums.pelicanparts.com/uploa...1292282898.gif I see the issue w/ the o/s feed, like I said just bend a line up from the caliper to the fixed point on the trailing arm You are probably better off w/ that caliper than the ones they originally sold w/ the GT-P kits |
I don't kow what the part number is - like I said it came in a kit. If there was a parts list I didn't see it/get it. These were ordered some time back right when the GTP kits were coming out and they phased out the Big Reds - I was surprised to see the Porsche script on the calipers (most others I have seen just say Brembo)
Bill - why would this rear be better than the GTP (although that is what I thought I had)? For bias? Also you say this rear rotor is NLA - I thought it was just a TT rotor pinned to a e-brake inner? |
I'm having some difficulty remembering what was used in the original GTP kits. From correspondence w/ Race Technology and some early adapters I thought I remembered Big red front and rear calipers. I just pulled the spec sheets and apparently my memory is much worse than I thought.
The original kits had the Brembo B caliper that you have in front on 993tt 322x32 2 piece rotor annulus w/ a flat 911 hat, these calipers had 40/44 pistons. the rears were an A-family as you have pictured on modified 322x28 993RS/tt rear rotors. The calipers had 28/30mm pistons. this setup is very heavily front biased, 2.1 vs usual 911 1.6. A number of early users reported front locking issues. I have no personal experience w/ them myself. But w/ that much front bias you may want to consider using a rear pad w/ more bite than the front also be sure to remove the stock 3.2 Carrera p/v. |
Thanks Bill - it just shows how much mis-information is floating around - I was told not to remove the p/v on the stock setup and use the 23mm. Where is the p/v on an 84 Carrera? By the m/c? |
Realized I never provided the picture I promised. Turns out I had to make a new feed line on one caliper when I couldn't get it to come free. I simply took a 12 in. pre-flared line and bent it to fit. 12 in. was just barely enough length to get it connected.
The line pictured here is an old original line. http://forums.pelicanparts.com/uploa...1313958185.jpg http://forums.pelicanparts.com/uploa...1313958208.jpg Looks like the Brembo kit caliper here would benefit from a banjo fitting like the original Porsche 930 Brembo rear caliper uses? |
Thanks Kevin - that is exactly how I ran mine also
| All times are GMT -8. The time now is 12:42 AM. |
