Fuse panel upgrade
I have a 74 911...after working on the headlights and those pesky german fuses...is there a kit or something that we can replace the fuse and relay panel in the truck with...My idea is something that uses the current modern fuses.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 12-04-2010, 02:41 PM
steely's Avatar
I think someone here posted an upgrade using the ATO/ATC type blade fuses.
on edit - found this --> Fuse panel upgrade to ATO type
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-04-2010, 02:57 PM
One issue with this upgrade is if you can make the mods equivalent to an OEM install and not disturb the original factory wiring positions. Otherwise, this upgrade is only good for you and only then based on your memory of what you did (unless you document every modification). IOW, will your auto tech give you the evil eye if/when you bring your car in for electrical diagnosis?
Sherwood
Old 12-04-2010, 05:00 PM
fred cook's Avatar
Fuse Panel Upgrade
When I built the ATO fuse panel for my SC coupe, I replicated the original fuse positions and added 3 extra fuses on the back end. That way, any diagnosis that may have to be done in the future can follow the original wiring schematic. The extra fuses are for some add ons like an oil cooler fan, etc. Since I completed the change to ATO fuses, I have only had one electrical issue and that was caused by a poor splice at the fuse box (my fault). It can be done, just be careful, lable all the wires as to position before removing and be certain to understand what each and every wire does before beginning. Also, keep in mind that there are some hardwired jumpers on the back side of the fuse blocks that will have to be duplicated. Good luck with your project.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 12-05-2010, 05:58 AM
Very Interesting
Did you build it with individual fuse holders or in racks?
Can you provide a picture for reference?
Old 12-05-2010, 11:05 AM
fred cook's Avatar
911 Fuse upgrade....
I built my own panel, designed so that it would mount to the stock base. The fuse holders came from Norway by way of a PP board member. Send me a PM with your regular email address and I will send you a set of files with the design for the fuse holder base and some wiring info. The files are done in Excel and are easier to send directly rather than try to put them on this BB. My car is a 1980 SC so you would need to compare what I used with the actual wiring on your car. The job is not hard, just tedious. On the plus side, it cleared up a number of small electrical gremlins that seemed to come and go at will.
FEC3
Old 12-05-2010, 01:11 PM
Happiest when Tinkering
gsmith660's Avatar
Fred was a great help when I did my panel upgrade he is very knowledgeable.
The thread with my upgrade.
My interpretation of the fuse panel upgrade
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-05-2010, 02:24 PM
schumicat's Avatar
Summit and JEGS sell fuse panels that could probably be adapted. It wouldn't be easy though because of the number of wires. One thing to do is to replace all the fuses with new ones of the same type. These types of fuses can be bad (work sporadically) even when not blown. Even if they don't look like they have much corrosion, they may not work properly.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 12-05-2010, 05:16 PM
fred cook's Avatar
Fuse Panel
Here is a picture of the fuse panel in my SC:
FEC3
Old 12-05-2010, 05:22 PM
French Import
zippy_gg's Avatar
Fred and Gsmith, did you use a ground bus system for your project? Thanks for the great write-up BTW.
Fred, PM sent.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-05-2010, 06:56 PM
gsmith660's Avatar
No I didn't kept it stock except for changing the type of fuse used. Probably why I still have some of my electrical gremlins that I have had for years I am sure they are grounding issues.
Old 12-06-2010, 03:49 AM
dshepp806's Avatar
Fred, PM sent.
Was "ground buss" used in the original design?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-06-2010, 04:48 PM
fred cook's Avatar
Fuse upgrade......
No, I did not use a ground buss. I duplicated what was on the original fuse blocks with one exception. That exception was to divide the feed for the evaporator fan and the front condenser fan. That particular load was separated to keep the load below 20 amps which is the max load rating for the fuse holders.
FEC3
Old 12-06-2010, 06:52 PM
gsmith660's Avatar
Doyle
No, the 911 uses local grounding posts part of the reason it has so many electrical gremlins
Old 12-06-2010, 06:55 PM
Fred you picture is very close to what i was envisioning...But the panel looks like its all one piece. I will send you a PM...I hope you have a parts list
Old 12-09-2010, 04:36 PM
